Rounded Rectangle ..Corner Radius???
Jun 15, 2011 Jun 15, 2011
How do you control the corner radius of a rounded rectangle box?
How to
104.6K
Jun 16, 2011 Jun 16, 2011
You can adjust the corner radius of a rounded rectangle mask as you're drawing it, but not after you have drawn it.
See this.
Look in the timeline under the shape layer contents. It's called roundness and it's in pixels.
Sorry should have been more clear... in a mask.
No adjustable rounded corners are available in a mask, however, if you make your mask smaller than you want then you can use the expand mask value to create a radius.
See this.
Aug 10, 2015 Aug 10, 2015
Genius answer - thanks!
Participant ,
Sep 22, 2017 Sep 22, 2017
I'm not getting the "Roundedness" option on my mask (screen-shot attached)
Mac
Masks are vector paths not parametric shapes so there is no corner radius you can adjust. You cal select all mask points and then press Ctrl/Cmnd + t to bring up Mask Transform, hold down the Ctrl/Cmnd key or Shift + Ctrl/Cmnd and resize the mask around it's geometric center and then use mask expansion to generate symmetrical round corners. The Mask path will still be square but expanding the mask with Mask Expansion will give you a radius on the corners. The amount of expansion is equal to the radius. In this case I have created a mask with a 78 pixel corner radius.
Another option would be to use a shape layer and the rectangle tool, adjust the size of the parametric shape using the tools shown in my first reply to this thread, then use the Shape layer as a Track Matte to create a mask or right click on the Rectangle Path and select convert to Bezier, set a keyframe to make sure you have the path selected, then copy. On the layer where you want the mask select the mask tool (g), click anywhere and paste.
Jul 12, 2019 Jul 12, 2019
Hey,
The round rectangle roundness option doesn't seem to be available in CC 2019. I'm looking to create a simple rounded rectangle.
EDIT: Ok so you need to press the little play button and select the Add Rounded Corners from the drop down.
You don’t have to add it If you created a parametric shape to begin with. When you create a shape, make sure the “bezier path” option is not selected in the tools menu and you will have a roundness parameter in the rectangle shape path parameters.
Apr 20, 2021 Apr 20, 2021
wow
Aug 25, 2021 Aug 25, 2021
If making a mask, roll the mouse wheel forward or backwards (depending on the size you need) before letting go of the right button that you are pushing down to drag it out. Congratulations, you have become as coordinated as an octopus. Your middle finger is now useful for two things instead of one.
Oct 10, 2021 Oct 10, 2021
Brilliant reply, answered the question with no pretentious bs and got me laughing on an adobe help forum somehow.
have a nice one
Mar 01, 2023 Mar 01, 2023
Perfect answer.  Thank you!
