you shouldn't be using a getter like a method. use something like:
var m:Mesh=enemycubeinstance.enemyMesh;
in the loop or outside the loop?
i cant keep decalring a var inside the loop
i don't see a loop and your error message isn't related to a loop.
Syntax for accessors (getters and setters) is the same as for properties. So, you loop must be:
for each (var el:ClassEnemyCube in models)
enemyMesh2 = el.enemyMesh;
Not - there are no parenthesis attached to enemyMesh.
