Hello,
I'm trying to create a custom installation script for Flash Builder 4.5 in silent mode.
I have created a flash builder msi installer using "Adobe Application Manager Enterprise Edition".
I would like to change the default installation directory during silent installation.
Could you please help ?
Thank you in advance.
Best regards,
Ryad
Hello,
Any news about this issue please ?
Kind regards,
Riadh
The install.xml in the "Adobe Flash Builder 4.5 Installer/deploy" folder will have the INSTALLDIR property. You can change this property to your custom location.
<?xml version="1.0" encoding="UTF-8"?>
<Deployment>
<Properties>
<!--Note that the INSTALLDIR value is machine specific. The value below is a suggested default value but may need to be overriden.-->
<Property name="INSTALLDIR">C:\Program Files\Adobe</Property>
</Properties>
<Payloads>
</Payloads>
</Deployment>
Unni G S
Hello,
Thank you for your help.
Is it possible please to use INSTALLDIR property as an environment variable ? Otherwise, is there another solution to change default directory
when launching silently the MSI generated by the "Adobe Application Manager Enterprise Edition"
Because I need to make install directory configurable (hard drive can be C: D: E: ...,). It will not be known before installation.
Best Regards,
Riadh
Hello,
I have tested your proposal, I have precised another custom installation directory for the property INSTALLDIR
But the installer creates directory always under "C:\Program files\Adobe", it seems that it is still using the default directory.
Can you help ?
Riadh
Best regards,
Riadh
Hello,
Any news about this request please ?
Best Regards,
Riadh
