1. Re: no button highlight after end action
Bill Hunt Jun 16, 2011 10:47 AM (in response to Bucketheadd)Kenny,
I assume that the Buttons' Sub-picture Highlights are available, when you first go to that Menu. Is that correct?
What is the exact End Action on that Timeliine?
Are there any Overrides set?
Perhaps posting a screen-cap of your Flowchart will help others spot the problem.
Good luck,
Hunt
2. Re: no button highlight after end action
Bucketheadd Jun 16, 2011 10:56 AM (in response to Bill Hunt)Thanks for the response. I figured this out in the meantime. I had my videos as transitions and my links to .wmv's that weren't in a timeline.
I learned that timelines are very important lol.
Thanks again Hunt you rock as usual
3. Re: no button highlight after end action
Bill Hunt Jun 17, 2011 12:20 PM (in response to Bucketheadd)Great news, and glad that you got the Timelines set up.
As for the WMV's, while Encore can Import them, they are not the ideal Assets, and can cause problems. If your Project is working fine for you, then just tuck that into the back of my memory, should you encounter issues with WMV Assets in the future.
The two ideal formats/CODEC's for DVD Projects are: DV-AVI Type II files w/ 48KHz 16-bit PCM/WAV (or DD AC3) Audio, or DVD-compliant MPEG-2's. I like using separate Audio and Video files, and then just add the Audio Asset to the appropriate Timeline.
Good luck,
Hunt
