22 Replies Latest reply on Oct 26, 2011 1:57 PM by DrAlexGor
    Multiple archive playback not working
    ahasannet Level 1
      I'm trying to play multiple archive from my application. After playing 1st archive, I've changed ConnectSessionContainer's archiveID but it won't work. So I've tried to logout session and after dispatching SessionEvent.SYNCHRONIZATION_CHANGE, I'm assigning archiveID to session and login. It works sometimes. Could you please give me any permanent solution for multiple playback.
      John
        • 1. Re: Multiple archive playback not working
          Jamie Ho Level 2
          Hi John,
          I tried to do this recently as well using PlaybackBar.as in the Recording sample app.  I did it like this and it seems to work:
          In PlaybackBar.as, I added:
          public function reset():void
          _archiveManager = _connectSession.archiveManager ;
          _archiveManager.addEventListener(ArchiveEvent.TOTAL_TIME_CHANGE,onTotalTimeChange);
          _archiveManager.addEventListener(ArchiveEvent.CURRENT_TIME_CHANGE,onCurrentTimeChange);
          _slider.minimum = 0 ;
          _slider.maximum = _archiveManager.totalTime/1000 ;
          _slider.labels = [_slider.minimum,uint(_slider.maximum/4),uint(_slider.maximum/2),uint(_slider.maximum*3/4 ),uint(_slider.maximum)];
          _slider.tickInterval = uint(_slider.maximum/4) ;
          _slider.value = 0;
          _archiveManager.seek(0);
          In my archive play back code, I added:
          container.logout();
          container.archiveID = recordingSelection.selectedItem.data;
          container.login();
          playback.connectSession = container;
          playback.reset();
          Hope this helps,
          Jamie
          1 person found this helpful
          • 2. Re: Multiple archive playback not working
            ahasannet Level 1
            It works little bit. Playback speed is not satisfactory. Is there any way to restrict protocol for playback auth?
            John
            • 3. Re: Multiple archive playback not working
              DrAlexGor Level 1
              LCCS v1.5 + F.P. 10.0:
              With this code I'm getting a few 2 RTEs in SessinoManagerPlayback[173] @ subscribeCollection(). Audio doesn't re-start, while video and drawings stuff re-plays. Looks like that code is requesting the playback before the whole connection is finished or the "SessionManagerPlayback._dataStreams" are not cleaned up. Any suggestions on what event/process I could wait on to make sure everything is set before re-playing?
              Here's my work flow:
              1) Load the sampleApp example in a new browser window
              2) playback starts and audio and video work fine ( see below "PLAYBACK #1" )
              3) I click the "reload" button
              4) playback stops, I see the "CONNECTSESSION:LOGOUT" trace
              5) playback starts again and I get 2 RTEs ( see below "PLAYBACK #2" )
              * NOTE: Audio never starts, but video and all drawn stuff works fine
              "PLAYBACK #1"
              [SWF] eclipse_workspace_3_5:StudioRecording:bin-debug:Recording.swf - 1,102,418 bytes after decompression
              Wed Jun 8 11:18:19 GMT-0400 2011    LCCS SDK Version : 1.5.0    Player Version : MAC 10,2,153,1
              11:18:19 GMT-0400    requestInfo https://connect.acrobat.com/<removed by alexg>?glt=g:playback&mode=xml&x=0.1789838057011366
              11:18:20 GMT-0400    #TicketService# ticket received: 35hol9j8a4rn
              11:18:20 GMT-0400    Getting FMS at https://na2.collaboration.adobelivecycle.com/fms?ticket=<removed by alexg>&playback=<removed by alexg>&proto=rtmfp, attempt #1/3
              11:18:20 GMT-0400    result: <fms>
                <origin>fms5.acrobat.com</origin>
                <proto_ports>rtmfp:1935,rtmps:443</proto_ports>
                <retry_attempts>2</retry_attempts>
              </fms>
              11:18:20 GMT-0400    protocols: [object ProtocolPortPair],[object ProtocolPortPair]
              11:18:20 GMT-0400    [attempt 1 of 2] Connecting to 0/1: rtmfp://fms5.acrobat.com/playback/<removed by alexg> #startProtosConnect#
              11:18:20 GMT-0400    tempNetStatusHandler 0/2,NetConnection.Connect.Success
              11:18:20 GMT-0400    isTunneling? false
              11:18:20 GMT-0400    is using RTMPS? false
              11:18:20 GMT-0400    #SessionManagerPlayback 1050 fms connected: [Event type="connected" bubbles=false cancelable=false eventPhase=2]
              11:18:20 GMT-0400    #SessionManagerPlayback 1051 ======= onConnected: play __PacingStream
              11:18:20 GMT-0400    #SessionManagerPlayback 1080 ======= onMetadata: play __StreamOffsets
              11:18:20 GMT-0400    #SessionManagerPlayback 1128 ======= receiveStreamOffset test_record_27/simpleNote, 61
              11:18:20 GMT-0400    #SessionManagerPlayback 1129 ======= receiveStreamOffset test_record_27/myCamera, 93
              11:18:20 GMT-0400    #SessionManagerPlayback 1129 ======= receiveStreamOffset test_record_27/FileManager, 127
              11:18:20 GMT-0400    #SessionManagerPlayback 1129 ======= receiveStreamOffset test_record_27/AVManager, 159
              11:18:20 GMT-0400    #SessionManagerPlayback 1130 ======= receiveStreamOffset test_record_27/swb, 189
              11:18:20 GMT-0400    #SessionManagerPlayback 1132 ======= receiveStreamOffset test_record_27/RoomManager, 220
              11:18:20 GMT-0400    #SessionManagerPlayback 1133 ======= receiveStreamOffset test_record_27/UserManager, 250
              11:18:20 GMT-0400    #SessionManagerPlayback 1135 ======= receiveStreamOffset test_record_27/883A0A60-0A2A-122A-6B36-6FAC8B3146E7, 277
              11:18:20 GMT-0400    #SessionManagerPlayback 1136 ======= receiveStreamOffset test_record_27/C4F0DA53-2E5D-8D42-7FD6-6FAC7B8463FF, 289
              11:18:20 GMT-0400    #SessionManagerPlayback 1137 ======= onOffsetStreamPlayStatus
              11:18:20 GMT-0400      . [object]
              11:18:20 GMT-0400        \\
              11:18:20 GMT-0400        .level [string]= status
              11:18:20 GMT-0400        .bytes [number]= 1246
              11:18:20 GMT-0400        .code [string]= NetStream.Play.Complete
              11:18:20 GMT-0400        .duration [number]= 0
              11:18:20 GMT-0400    #SessionManagerPlayback 1276 receiveLogin:
              11:18:20 GMT-0400        .descriptor [object]= [object Object]
              11:18:20 GMT-0400    RECEIVED LOGIN AT SESSION
              11:18:20 GMT-0400      .user descriptor from server [object]
              11:18:20 GMT-0400        .affiliation [number]= 10
              11:18:20 GMT-0400        .userID [number]= 0
              11:18:25 GMT-0400    #SessionManagerPlayback 6033 ======= subscribeCollection root
              11:18:25 GMT-0400    #SessionManagerPlayback 6033 ======= subscribeCollection __RootCollection - play
              11:18:25 GMT-0400    #SessionManagerPlayback 6053 ======= subscribeCollection UserManager - play
              11:18:25 GMT-0400    #SessionManagerPlayback 6055 ======= subscribeCollection FileManager - play
              11:18:25 GMT-0400    #SessionManagerPlayback 6057 ======= subscribeCollection AVManager - play
              11:18:25 GMT-0400    #SessionManagerPlayback 6058 ======= subscribeCollection RoomManager - play
              11:18:25 GMT-0400    RECEIVENODES UserManager
              11:18:25 GMT-0400    receiveAllSynchData UserManager
              11:18:25 GMT-0400    RECEIVENODES RoomManager
              11:18:25 GMT-0400    receiveAllSynchData RoomManager
              11:18:25 GMT-0400    checkManagerSync:[object RoomManager]
              11:18:25 GMT-0400    RECEIVENODES AVManager
              11:18:25 GMT-0400    receiveAllSynchData AVManager
              11:18:25 GMT-0400    checkManagerSync:[object StreamManager]
              11:18:25 GMT-0400    RECEIVENODES FileManager
              11:18:25 GMT-0400    receiveAllSynchData FileManager
              11:18:25 GMT-0400    checkManagerSync:[object FileManager]
              11:18:25 GMT-0400    checkManagerSync:[object UserManager]
              SeekTime: -277
              11:18:25 GMT-0400    #SessionManagerPlayback 6338 seek and play
              11:18:25 GMT-0400    #SessionManagerPlayback 6353 ======= subscribeCollection myCamera - play
              11:18:26 GMT-0400    #SessionManagerPlayback 6360 ======= subscribeCollection simpleNote - play
              11:18:26 GMT-0400    #SessionManagerPlayback 6362 ======= subscribeCollection simpleNote - play
              11:18:26 GMT-0400    #SessionManagerPlayback 6416 ======= subscribeCollection swb - play
              11:18:26 GMT-0400    RECEIVENODES simpleNote
              11:18:26 GMT-0400    receiveAllSynchData simpleNote
              11:18:26 GMT-0400    RECEIVENODES myCamera
              SeekTime: -289
              11:18:26 GMT-0400    #SessionManagerPlayback 6557 seek and play
              11:18:26 GMT-0400    receiveAllSynchData myCamera
              11:18:26 GMT-0400    RECEIVENODES swb
              11:18:26 GMT-0400    receiveAllSynchData swb
              we are live--------
              11:18:43 GMT-0400    #SessionManagerPlayback 23990 ======= onPlayStatus
              11:18:43 GMT-0400      . [object]
              11:18:43 GMT-0400        \\
              11:18:43 GMT-0400        .level [string]= status
              11:18:43 GMT-0400        .bytes [number]= 6198
              11:18:43 GMT-0400        .code [string]= NetStream.Play.Complete
              11:18:43 GMT-0400        .duration [number]= 8
              ---11:18:43 GMT-0400    #SessionManagerPlayback 24058 ======= onPlayStatus
              11:18:43 GMT-0400        .bytes [number]= 5344
              11:18:43 GMT-0400        .duration [number]= 0
              11:18:43 GMT-0400    #SessionManagerPlayback 24125 ======= onPlayStatus
              11:18:43 GMT-0400        .bytes [number]= 11713
              11:18:43 GMT-0400    #SessionManagerPlayback 24131 ======= onPlayStatus
              11:18:43 GMT-0400        .bytes [number]= 4360
              11:18:43 GMT-0400    #SessionManagerPlayback 24139 ======= onPlayStatus
              --11:18:43 GMT-0400        \\
              11:18:43 GMT-0400        .bytes [number]= 976
              11:18:43 GMT-0400    #SessionManagerPlayback 24159 ======= onPlayStatus
              11:18:43 GMT-0400        .bytes [number]= 1151
              11:18:44 GMT-0400    #SessionManagerPlayback 24441 ======= onPlayStatus
              11:18:44 GMT-0400      . [object]
              11:18:44 GMT-0400        \\
              11:18:44 GMT-0400        .level [string]= status
              11:18:44 GMT-0400        .bytes [number]= 232791
              11:18:44 GMT-0400        .code [string]= NetStream.Play.Complete
              11:18:44 GMT-0400        .duration [number]= 8
              11:18:44 GMT-0400    #SessionManagerPlayback 24573 ======= onPlayStatus
              11:18:44 GMT-0400        .bytes [number]= 94362
              11:18:44 GMT-0400    #SessionManagerPlayback 24606 ======= onPlayStatus
              11:18:44 GMT-0400        .bytes [number]= 1284
              11:18:44 GMT-0400        .duration [number]= 0
              11:18:44 GMT-0400    #SessionManagerPlayback 24623 ======= onPlayStatus
              11:18:44 GMT-0400        .bytes [number]= 1573
              ---------- we are done
              11:18:56 GMT-0400    CONNECTSESSION:LOGOUT
              "PLAYBACK #2"
              11:19:01 GMT-0400    LCCS SDK Version : 1.5.0    Player Version : MAC 10,2,153,1
              11:19:01 GMT-0400    requestInfo https://connect.acrobat.com/<removed by alexg>?glt=g:playback&mode=xml&x=0.204225055873394
              11:19:01 GMT-0400    #SessionManagerPlayback 41711 ======= seek 0
              11:19:01 GMT-0400    requestInfo https://connect.acrobat.com/<removed by alexg>?glt=g:playback&mode=xml&x=0.24730322184041142
              11:19:01 GMT-0400    #SessionManagerPlayback 41712 ======= seek 0
              11:19:01 GMT-0400    #SessionManagerPlayback 41842 receiveLogin:
              11:19:01 GMT-0400      . [object]
              11:19:01 GMT-0400        \\
              11:19:01 GMT-0400        .descriptor [object]= [object Object]
              11:19:01 GMT-0400    RECEIVED LOGIN AT SESSION
              11:19:01 GMT-0400      .user descriptor from server [object]
              11:19:01 GMT-0400        .affiliation [number]= 10
              11:19:01 GMT-0400        .userID [number]= 0
              11:19:01 GMT-0400    #SessionManagerPlayback 41849 ======= subscribeCollection root
              TypeError: Error #2007: Parameter connection must be non-null.
                  at flash.net::NetStream/ctor()
                  at flash.net::NetStream()
                  at com.adobe.rtc.session.managers::SessionManagerPlayback/http://www.adobe.com/2006/connect/cocomo/session/internal::subscribeCollection()[/Users/al exg/Documents/com.adobe.lccs/libs/player10/src/com/adobe/rtc/session/managers/SessionManag erPlayback.as:137]
                  at com.adobe.rtc.messaging.manager::MessageManager/subscribe()[/Users/alexg/Documents/com.ad obe.lccs/libs/player10/src/com/adobe/rtc/messaging/manager/MessageManager.as:196]
                  at com.adobe.rtc.session::ConnectSession/onLogin()[/Users/alex/Documents/com.adobe.lccs/libs /player10/src/com/adobe/rtc/session/ConnectSession.as:425]
                  at flash.events::EventDispatcher/dispatchEventFunction()
                  at flash.events::EventDispatcher/dispatchEvent()
                  at com.adobe.rtc.session.managers::SessionManagerBase/receiveLogin()[/Users/alexg/Documents/ com.adobe.lccs/libs/player10/src/com/adobe/rtc/session/managers/SessionManagerBase.as:313]
                  at com.adobe.rtc.session.managers::SessionManagerFMS/receiveLogin()[/Users/alexg/Documents/c om.adobe.lccs/libs/player10/src/com/adobe/rtc/session/managers/SessionManagerFMS.as:293]
                  at com.adobe.rtc.session.managers::SessionManagerPlayback/receiveLogin()[/Users/alexg/Docume nts/com.adobe.lccs/libs/player10/src/com/adobe/rtc/session/managers/SessionManagerPlayback .as:127]
                  at Function/http://adobe.com/AS3/2006/builtin::apply()
                  at SetIntervalTimer/onTimer()
                  at flash.utils::Timer/_timerDispatch()
                  at flash.utils::Timer/tick()
              11:19:04 GMT-0400    #SessionManagerPlayback 44775 receiveLogin:
              11:19:04 GMT-0400      . [object]
              11:19:04 GMT-0400        \\
              11:19:04 GMT-0400        .descriptor [object]= [object Object]
              11:19:04 GMT-0400    RECEIVED LOGIN AT SESSION
              11:19:04 GMT-0400      .user descriptor from server [object]
              11:19:04 GMT-0400        .affiliation [number]= 10
              11:19:04 GMT-0400        .userID [number]= 0
              11:19:04 GMT-0400    #SessionManagerPlayback 44782 ======= subscribeCollection root
                  at com.adobe.rtc.session::ConnectSession/onLogin()[/Users/alexg/Documents/com.adobe.lccs/lib s/player10/src/com/adobe/rtc/session/ConnectSession.as:425]
              11:19:05 GMT-0400    #TicketService# ticket received: 17mhp7hm17ffp
              11:19:05 GMT-0400    Getting FMS at https://na2.collaboration.adobelivecycle.com/fms?ticket=17mhp7hm17ffp&playback=test_record _27&proto=rtmfp, attempt #1/3
              11:19:05 GMT-0400    result: <fms>
              </fms>
              11:19:05 GMT-0400    protocols: [object ProtocolPortPair],[object ProtocolPortPair]
              11:19:05 GMT-0400    [attempt 1 of 2] Connecting to 0/1: rtmfp://fms5.acrobat.com/playback/na2-c0798bf5-4164-4a17-978e-8495b1025a2d/localdevroom5/ test_record_27 #startProtosConnect#
              11:19:06 GMT-0400    tempNetStatusHandler 0/2,NetConnection.Connect.Success
              11:19:06 GMT-0400    isTunneling? false
              11:19:06 GMT-0400    is using RTMPS? false
              11:19:06 GMT-0400    #SessionManagerPlayback 46443 fms connected: [Event type="connected" bubbles=false cancelable=false eventPhase=2]
              11:19:06 GMT-0400    #SessionManagerPlayback 46444 ======= onConnected: play __PacingStream
              11:19:06 GMT-0400    #SessionManagerPlayback 46465 ======= onMetadata: play __StreamOffsets
              11:19:06 GMT-0400    #SessionManagerPlayback 46491 ======= receiveStreamOffset test_record_27/simpleNote, 61
              11:19:06 GMT-0400    #SessionManagerPlayback 46492 ======= receiveStreamOffset test_record_27/myCamera, 93
              11:19:06 GMT-0400    #SessionManagerPlayback 46492 ======= receiveStreamOffset test_record_27/FileManager, 127
              11:19:06 GMT-0400    #SessionManagerPlayback 46493 ======= receiveStreamOffset test_record_27/AVManager, 159
              11:19:06 GMT-0400    #SessionManagerPlayback 46494 ======= receiveStreamOffset test_record_27/swb, 189
              11:19:06 GMT-0400    #SessionManagerPlayback 46495 ======= receiveStreamOffset test_record_27/RoomManager, 220
              11:19:06 GMT-0400    #SessionManagerPlayback 46497 ======= receiveStreamOffset test_record_27/UserManager, 250
              11:19:06 GMT-0400    #SessionManagerPlayback 46498 ======= receiveStreamOffset test_record_27/883A0A60-0A2A-122A-6B36-6FAC8B3146E7, 277
              11:19:06 GMT-0400    #SessionManagerPlayback 46498 ======= receiveStreamOffset test_record_27/C4F0DA53-2E5D-8D42-7FD6-6FAC7B8463FF, 289
              11:19:06 GMT-0400    #SessionManagerPlayback 46499 ======= onOffsetStreamPlayStatus
              11:19:06 GMT-0400      . [object]
              11:19:06 GMT-0400        \\
              11:19:06 GMT-0400        .level [string]= status
              11:19:06 GMT-0400        .bytes [number]= 1246
              11:19:06 GMT-0400        .code [string]= NetStream.Play.Complete
              11:19:06 GMT-0400        .duration [number]= 0
              11:19:06 GMT-0400    #SessionManagerPlayback 46641 receiveLogin:
              11:19:06 GMT-0400        .descriptor [object]= [object Object]
              11:19:06 GMT-0400    RECEIVED LOGIN AT SESSION
              11:19:06 GMT-0400      .user descriptor from server [object]
              11:19:06 GMT-0400        .affiliation [number]= 10
              11:19:06 GMT-0400        .userID [number]= 0
              11:19:06 GMT-0400    #SessionManagerPlayback 46651 ======= subscribeCollection root
              11:19:06 GMT-0400    #SessionManagerPlayback 46651 ======= subscribeCollection __RootCollection - play
              11:19:06 GMT-0400    #SessionManagerPlayback 46664 ======= subscribeCollection UserManager - play
              11:19:06 GMT-0400    #SessionManagerPlayback 46664 ======= subscribeCollection FileManager - play
              11:19:06 GMT-0400    #SessionManagerPlayback 46664 ======= subscribeCollection AVManager - play
              11:19:06 GMT-0400    #SessionManagerPlayback 46666 ======= subscribeCollection RoomManager - play
              11:19:06 GMT-0400    RECEIVENODES UserManager
              11:19:06 GMT-0400    receiveAllSynchData UserManager
              11:19:06 GMT-0400    RECEIVENODES RoomManager
              11:19:06 GMT-0400    receiveAllSynchData RoomManager
              11:19:06 GMT-0400    checkManagerSync:[object RoomManager]
              11:19:06 GMT-0400    RECEIVENODES AVManager
              SeekTime: -289
              11:19:06 GMT-0400    #SessionManagerPlayback 46705 seek and play
              11:19:06 GMT-0400    receiveAllSynchData AVManager
              11:19:06 GMT-0400    checkManagerSync:[object StreamManager]
              11:19:06 GMT-0400    RECEIVENODES FileManager
              11:19:06 GMT-0400    receiveAllSynchData FileManager
              11:19:06 GMT-0400    checkManagerSync:[object FileManager]
              11:19:06 GMT-0400    checkManagerSync:[object UserManager]
              11:19:24 GMT-0400    #SessionManagerPlayback 64531 ======= onPlayStatus
              11:19:24 GMT-0400      . [object]
              11:19:24 GMT-0400        \\
              11:19:24 GMT-0400        .level [string]= status
              11:19:24 GMT-0400        .bytes [number]= 232791
              11:19:24 GMT-0400        .code [string]= NetStream.Play.Complete
              11:19:24 GMT-0400        .duration [number]= 8
              11:19:24 GMT-0400    #SessionManagerPlayback 64592 ======= onPlayStatus
              11:19:24 GMT-0400        .bytes [number]= 6198
              11:19:24 GMT-0400        .duration [number]= 7
              11:19:24 GMT-0400    #SessionManagerPlayback 64624 ======= onPlayStatus
              11:19:24 GMT-0400        .bytes [number]= 5344
              11:19:24 GMT-0400        .duration [number]= 0
              11:19:24 GMT-0400    #SessionManagerPlayback 64691 ======= onPlayStatus
              11:19:24 GMT-0400        .bytes [number]= 4360
              11:19:24 GMT-0400    #SessionManagerPlayback 64725 ======= onPlayStatus
              11:19:24 GMT-0400        .bytes [number]= 1151
              11:19:24 GMT-0400    #SessionManagerPlayback 64758 ======= onPlayStatus
              11:19:24 GMT-0400        .bytes [number]= 976
              Alex G.
              • 4. Re: Multiple archive playback not working
                nzezelj Level 2
                Hi Alex,
                Thanks for reporting the issue. Let me look into it and update you as soon as I have something.
                Nikola
                • 5. Re: Multiple archive playback not working
                  DrAlexGor Level 1
                  Thanks Nikola,
                  I've been playing around with different types of playback and re-play abilities in the sampleApp. Here's the best solution I've found:
                          public function reset():void {
                              _slider.minimum = 0;
                              _slider.maximum = _archiveManager.totalTime/1000;
                              _slider.labels = [_slider.minimum, uint(_slider.maximum/4), uint(_slider.maximum/2), uint(_slider.maximum*3/4), uint(_slider.maximum)];
                              _slider.tickInterval = uint(_slider.maximum/4);
                              _slider.value = 0;
                  and
                              private function onPlayRecording28():void {
                                  _archiveID = "test_record_28";
                                  if (cSession) {
                                      cSession.logout();
                                      cSession.close("closing because docs say I need to do this, yet without closing I can still get this example to work....odd");
                                  var timer:Timer = new Timer(3000);
                                  timer.addEventListener(TimerEvent.TIMER, onDone);
                                  timer.start();
                              private function onDone(event:TimerEvent):void {
                                  Timer(event.target).stop();
                                  if (cSession) {
                                      //wow what a hack!
                                      playbackBar.reset();
                                      onConnectSessionContainerPreInit();
                                      cSession.archiveManager.currentTime = 0;
                                      cSession.archiveManager.seek(0);           // without this code, the 2nd playback will start where 1st video stopped
                                      cSession.archiveManager.pause(true);
                                      //ok lets login and see if we can get both audio and video; normally audio doesn't come back
                                      cSession.login();
                                      // I'm giving the login function a chance to log in and LCCS to bootstrap... I can't find an event to listen to in order to trigger the playback again
                                      var timer:Timer = new Timer(10000);
                                      timer.addEventListener(TimerEvent.TIMER, onReadyToGo);
                                      timer.start();
                              private function onReadyToGo(event:TimerEvent):void {
                                  cSession.archiveManager.pause(false);
                  I'm still getting the 2 RTEs I described earlier, but I'm finally getting video playback of 2 different videos without having to reload the whole app.
                  This is not right way to do replay for sure, so please adivse,
                  Alex G.
                  • 6. Re: Multiple archive playback not working
                    DrAlexGor Level 1
                    Any luck getting play + replay working ?
                    Seems the approach you guys are taking is "login()" + "seek()" which works to start playback, yet if you seek() again to any point on the timeline, the audio doesn't play.
                    • 7. Re: Multiple archive playback not working
                      Nigel Pegg Level 4
                      Hi Alex,
                      Instead of re-using the existing ConnectSession, why not take a componentized approach here? You could put the whole thing, minus the archiveID, in an MXML component which contains a ConnectSessionContainer, the slider, and all other componentry relevant to the recording. You'd pass the archiveID to the component to kick it off. When you want to change recordings, close() the existing component (which should close() the session and all componentry), and then create another instance of that component with the new archiveID.
                      It shouldn't be much more work than what you're doing today (just some refactoring), but should work more reliably.
                      In the meantime, we'll look into this, but I'm not sure how high the priority should be if the workflow above does work.
                        thanks
                         nigel
                      • 8. Re: Multiple archive playback not working
                        DrAlexGor Level 1
                        Hey Nigel,
                        1) My primary question is what's the magic sequence of method calls to play audio at any point on the timeline?
                        ArchiveManager.seek() only works on video and vector objects, audio simply cuts off. Imagine a 24 hour long video/audio that you can't start playing at the 23 hour mark.
                        2) Your suggestion only answers the the original question was in this thread, which I've gotten working with and without having a top level MXML component. For anyone who's trying to re-play working I suggest the following:
                        a) Here's a simple example of how to reload all components from scratch ( I welcome corrections )
                        b) Flex 4.1 SDK + FP10.0
                        <?xml version="1.0" encoding="utf-8"?>
                        <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                                       xmlns:s="library://ns.adobe.com/flex/spark"
                                       xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                            <fx:Declarations>
                                <!-- Place non-visual elements (e.g., services, value objects) here -->
                            </fx:Declarations>
                            <fx:Script>
                                <![CDATA[
                                    private function onKill():void {
                                        topLevel.removeAllChildren();
                                    private function onLoad():void {
                                        topLevel.createComponentsFromDescriptors(true);
                            </fx:Script>
                            <mx:VBox>
                                <mx:HBox>
                                    <mx:Button id="kill" label="kill" click="onKill()"/>
                                    <mx:Button id="load" label="load" click="onLoad()"/>
                                </mx:HBox>
                                <mx:VBox id="topLevel" creationPolicy="none" >
                                    <mx:Button label="hey there" />
                                    <mx:ColorPicker width="100" height="150"/>
                                </mx:VBox>
                            </mx:VBox>
                        </s:Application>
                          c) In order to make this work with ConnectSessionContainer you'll also need to add "connectSessionContainer.validateDisplayList()" after "topLevel.createComponentsFromDescriptors(true);"
                        Alex G.
                        • 9. Re: Multiple archive playback not working
                          Nigel Pegg Level 4
                          Hi Alex,
                          I haven't experienced any problems with Audio seek - could you send the
                          simplest app you can which reproduces this issue? I'd be pretty interested
                          in checking it out.
                          If you're not switching between archives, do you still encounter this
                          issue?
                             nigel
                          • 10. Re: Multiple archive playback not working
                            DrAlexGor Level 1
                            Sure, I took the example you guys provide "Recording" and added AudioPublisher and AudioSubscriber in the Recording.mxml and Playback.mxml. During playback, the audio plays fine, until you click anywhere on the PlaybackBar/timeline.
                            Recording.mxml
                                           xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:rtc="http://ns.adobe.com/rtc">
                                <fx:Declarations>
                                    <rtc:AdobeHSAuthenticator id="auth"  userName="{ourUserName}" password="{ourPassword}" />
                                </fx:Declarations>
                                <fx:Script>
                                    <![CDATA[
                                         * ADOBE SYSTEMS INCORPORATED
                                         * Copyright 2010 Adobe Systems Incorporated
                                         * All Rights Reserved.
                                         * NOTICE: Adobe permits you to use, modify, and distribute this file in accordance with the
                                         * terms of the Adobe license agreement accompanying it.If you have received this file from a
                                         * source other than Adobe, then your use, modification, or distribution of it requires the prior
                                         * written permission of Adobe.
                                        import com.adobe.rtc.session.managers.SessionManagerPlayback;
                                        import mx.utils.Base64Encoder;
                                        import com.adobe.rtc.core.session_internal ;
                                        import com.adobe.rtc.archive.ArchiveManager ;
                                        [Bindable] public var ourRoomURL:String = "";
                                        [Bindable] public var ourUserName:String = "";
                                        [Bindable] public var ourPassword:String = "";
                                        private function onBtnClick():void
                                            cSession.archiveManager.isRecording = record.selected ;
                                        private function onAudioPubreationComplete():void {
                                            audioPub.publish();
                                </fx:Script>
                                <rtc:ConnectSessionContainer id="cSession" authenticator="{auth}" width="100%" height="100%"
        roomURL="{ourRoomURL}" >
                                    <mx:HBox top="10" right="10" left="10" bottom="10" verticalGap="6" horizontalAlign="center">
                                        <mx:VBox width="100%" height="100%" >
                                            <rtc:AudioPublisher id="audioPub" creationComplete="onAudioPubreationComplete()" gain="100"/>
                                            <rtc:AudioSubscriber id="audioSub"/>
                                            <rtc:SharedWhiteBoard id="swb" width="100%" height="100%" />
                                            <rtc:WebCamera id="myCamera" width="200" height="200" />
                                            <rtc:Note id="simpleNote" width="100%" height="100%" />
                                            <mx:Button id="record" label="record" click="onBtnClick()" toggle="true" height="30"   />
                                        </mx:VBox>
                                    </mx:HBox>
                                </rtc:ConnectSessionContainer>
                            </s:Application>
                            and Playback.mxml
                                           xmlns:rtc="http://ns.adobe.com/rtc" xmlns:currentDir="*" >
                                <fx:Declarations>
                                    <rtc:PlaybackAuthenticator id="auth" />
                                </fx:Declarations>
                                <fx:Script>
                                    <![CDATA[
                                         * terms of the Adobe license agreement accompanying it. If you have received this file from a
                                </fx:Script>
                                <rtc:ConnectSessionContainer id="cSession" authenticator="{auth}" width="100%" height="100%" roomURL="{ourRoomURL}" >
                                            <rtc:AudioPublisher id="audioPub" gain="100"/>
                                            <currentDir:PlaybackBar width="100%" height="200" />
                                        </mx:VBox>
                                    </mx:HBox>
                            </s:Application>
                            I'll try to attach the whole project as well....if I can find the 'attachment' button haha
                            • 11. Re: Multiple archive playback not working
                              DrAlexGor Level 1
                              So I debugged into AudioSubscriber a) on the initial playback b) on the secondary playback ( clicking on the timeline )
                              A) Initial playback:
                              AudioSubscriber() > initialize() - which invokes subscribe() > ......etc .... > playSteam(...) line 632:
                              if ( _netStreamTable[streamDescriptor.id] == null ) {
                              Since _netStreamTable returns null ( it's a null object at this point ), I'm guessing because we haven't played any streams yet. Thus this block gets executed and when getAndPlayAVStream(); is invoked we add that stream to the _netStreamTable
                              B) On second playback / when I click anywhere on the playbar:
                              i) AudioSubscriber.onSynchronizationChange() is invoked and the above mentioned "playStream() line 632 is called again
                              ii) However this time that block of code doesn't execute sine the _netStreamTable contains the playing stream. I suppose this was done to prevent the same audio stream from playing twice ?
                              At this point the audio becomes either muted or stops???
                              • 12. Re: Multiple archive playback not working
                                Nigel Pegg Level 4
                                Hi Alex,
                                Interesting - this is super-helpful research. As you switch from one
                                archive to another, could you close() the audioSubscriber and then subscribe
                                when you switch? This should solve your issue.
                                  nigel
                                • 13. Re: Multiple archive playback not working
                                  DrAlexGor Level 1
                                  Nigel, I'm not switching archives in the sample code I added. It's the most plain example of using audio + video recording.
                                  So I modified PlaybackBar.onChange() from:
                                          private function onChange(p_evt:Event):void
                                              _archiveManager.seek(_slider.value*1000);
                                              if ( (_slider.value*1000) < _archiveManager.totalTime ) {
                                                  _playPauseBtn.label = "Pause/Stop the Recording" ;
                                  to
                                              _audioSubscriber.close();
                                              _archiveManager.currentTime = _slider.value*1000;
                                              _audioSubscriber.subscribe();
                                  It's unreliable, but the audio stream does playback sometimes and mostly at the right spot. I'm pretty sure I need to wait on some event or a better way to reliably play the audio, should I be listening to some even from audioSubscriber? before seeking/subscribing?
                                  • 14. Re: Multiple archive playback not working
                                    DrAlexGor Level 1
                                    I found this the closest to working aside from getting the RTEs from time to time:
                                                _archiveManager.pause(true);
                                                _archiveManager.pause(false);
                                    The RTEs are still the same ( as described in more detail earlier in this post ):
                                    0:52:28 GMT-0400    #SessionManagerPlayback 327002 ======= subscribeCollection root
                                        at com.adobe.rtc.session.managers::SessionManagerPlayback/http://www.adobe.com/2006/connect/cocomo/session/internal::subscribeCollection()[/Users/ag oryuk/Documents/com.adobe.lccs/libs/player10/src/com/adobe/rtc/session/managers/SessionMan agerPlayback.as:137]
                                        at com.adobe.rtc.messaging.manager::MessageManager/subscribe()[/Users/agoryuk/Documents/com. adobe.lccs/libs/player10/src/com/adobe/rtc/messaging/manager/MessageManager.as:196]
                                        at com.adobe.rtc.session::ConnectSession/onLogin()[/Users/agoryuk/Documents/com.adobe.lccs/l ibs/player10/src/com/adobe/rtc/session/ConnectSession.as:425]
                                        at com.adobe.rtc.session.managers::SessionManagerBase/receiveLogin()[/Users/agoryuk/Document s/com.adobe.lccs/libs/player10/src/com/adobe/rtc/session/managers/SessionManagerBase.as:31 3]
                                        at com.adobe.rtc.session.managers::SessionManagerFMS/receiveLogin()[/Users/agoryuk/Documents /com.adobe.lccs/libs/player10/src/com/adobe/rtc/session/managers/SessionManagerFMS.as:293]
                                        at com.adobe.rtc.session.managers::SessionManagerPlayback/receiveLogin()[/Users/agoryuk/Docu ments/com.adobe.lccs/libs/player10/src/com/adobe/rtc/session/managers/SessionManagerPlayba ck.as:127]
                                    • 15. Re: Multiple archive playback not working
                                      Nigel Pegg Level 4
                                      I see - if you're not switching from archive to archive, putting these
                                      details in a new thread might help prevent confusion =).
                                        Still, all that you're posting is very helpful, so thanks again. We're
                                      looking into the issue, including the RTE, which I can repro on occasion.
                                        nigel
                                      • 16. Re: Multiple archive playback not working
                                        DrAlexGor Level 1
                                        Sorry Nigel, the two were showing up in either case, but the playback issues were more visible when user would select something on a timeline. I do appreciate your help, I made the assumption that audio would work the same as video instead of trying to cleanup and subscribe myself.
                                        Cool if you guys find out anything, let me know
                                        Alex
                                        • 17. Re: Multiple archive playback not working
                                          Nigel Pegg Level 4
                                          Yeah, this is a weird one, since I've seen the RTE, but not the audio
                                          issue. But the code you pointed out here is a big help - we'll be digging in
                                          deeper over the next week.
                                          thanks
                                            nigel
                                          • 18. Re: Multiple archive playback not working
                                            adam+k
                                            any progress on this? i'm also trying to do playbackback of multiple archives within the same application and running into similar issues.  before i forge ahead i just want to know if this has already been solved.
                                            • 19. Re: Multiple archive playback not working
                                              DrAlexGor Level 1
                                              I think things have been working well since LCCS 2.0.0. I haven't seen the RTEs and after LCCS 1.5.0 I haven't seen problems with multi-archive playback. I haven't tested this in 2.1.0.
                                              Try it out and let us know what you find
                                              • 20. Re: Multiple archive playback not working
                                                adam+k Level 1
                                                so what's the process for playing back a second archive?  do you need to .close() all of your pods/subscribers, then close() the ConnectSession, then reset the archiveID in archiveManager and login to the ConnectSession again?
                                                • 21. Re: Multiple archive playback not working
                                                  nzezelj Level 2
                                                  Hi Adam,
                                                  I believe your question has been answered in post 8. of this thread by Alex.
                                                  Nikola
                                                  • 22. Re: Multiple archive playback not working
                                                    DrAlexGor Level 1
                                                    Yup essentially it's:
                                                    1) cSession.close()
                                                    2) audioSubscriber.close(); // if you have one
                                                    3) if you are using the PlaybackBar.as I added/modified and call "playbackBar.reset();"
        _slider.value = 0;
                                                    4) set the archiveID again
                                                    5) create a new PlaybackSession and set that on the cSession.authenticator = new PlaybackAuthenticator();
                                                    6) audioSubscriber.subscribe();
                                                    7) cSession.archiveManager.currentTime = 0;
                                                        cSession.login();
                                                    This works for me but you'll definitely have to play around with it yourself, to get a better feel when to set archiveID correctly and when to close()/login()
                                                    Alex G.
