Java / AS3 mapping
Avatar
Former Community Member
Is [RemoteClass(alias="")] can apply to Fault.rootCause ?
Said differently, can I map a java exception (thrown during a
remote service call) to a custom AS class ?
Thanks in advance
Thierry.
Avatar
Level 2
Hi Thierry. The Fault.rootCause property contains a
serialized map of the exception but you can't map the exception to
a custom AS class.
Avatar
Hi Alex,
First of all, I thank you for your answer.
Something really funny: I tried several times to map my
exception before
I realized that even
ResultEvent.result didn't map anymore with
my remote result class !
The cause was the following: all the remote service calls
were performed within
a library, and it seems that the Flex library compiler does
not generate the
[RemoteObject]
tag artifacts (unlike the Flex application compiler).
Now, I call the
flash.net.registerClassAlias method for each remote class
(in a static region) and it works fine.
Last but not least, the exceptions are correctly mapped with
my fault events too !
I need you to confirm I ain't drunk !!!!!
If I am right, maybe the documentation could emphasize on
that feature ?
Thierry
Avatar
Level 3
Hi Thierry,
Are you sure you've spelled the metadata correctly?
It needs to be: [RemoteClass(alias="...")]
Not: [RemoteObject(alias="...")]
If the compiler encounters metadata it is not familiar with
the metadata is simply ignored.
The [RemoteClass...] metadata is a convenience tag. When
present, the compiler generates the appropriate call to
registerClassAlias() for you and ensures that the call is made
before the application starts running and requests instances of
this type from the server.
Best,
Seth
Avatar
Hi Seth,
Sorry I spelled incorrectly
[RemoteClass(alias="")] in my last post. So it is not the
issue.
The fact is that the compiler does not generate the
RemoteClass artifacts (i.e registerClassAlias)
while compiling a
library
. It works fine with an
application
You can join my point of view by creating a
library
project including a
[RemoteClass(alias="")] tag, adding the
-keep-generated-actionscript=true compiler option, and
finally scanning the generated AS files: no trace
of any
registerClassAlias call is found.
That's why I have to do it "manually".
Rgds,
Thierry
Avatar
Level 3
Hi Thierry,
I've finally had the chance to try to repro the library
project issue you had and it works fine for me.
1. I created a simple library project with one class in it,
Foo.as, that has RemoteClass metadata:
package
[RemoteClass(alias="com.fake.Foo")]
public class Foo
2. I made sure this class was selected to be included in the
generated swc (Properties > Flex Library Build Path, Classes
tab) and I compiled to generate the swc.
3. I created another simple non-library project and added
"-keep" to the compiler command line arguments (Properties >
Flex Compiler > Additional compiler arguments), and added the
generated swc from the first project (Properties > Flex Build
Path, Libary path tab > Add SWC).
4. Here's the simple mxml app:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
creationComplete="initApp()">
<mx:Script>
<![CDATA[
import Foo;
private function initApp():void
var f:Foo = new Foo();
</mx:Script>
</mx:Application>
5. And here's the code-gen'ed line in
_<appname>_FlexInit-generated.as that corresponds to my
flash.net.registerClassAlias("com.fake.Foo", Foo);
So in this simple scenario everything worked as expected. You
may want to try refreshing your projects, re'adding the swc, etc.
to try to identify why this was failing for you.
Best,
Seth
Avatar
Hi Seth,
Thanks for your investigations ; I keep your results in mind.
But I have to apologize because I missed to give you more
informations about my project.
The fact is that my library is dynamically loaded (using the
Loader class) and are
never included in my application "library path".
Also, with your prototype, what's happen if you decide to
link your library as a RSL for instance ?
I imagine the artifacts are not generated too.
I think that only a library "statically" included within an
application (i.e with "merged into code" option selected)
can see its binding artifacts generated. Do you agree ?
Thanks again,
Thierry.
Avatar
Level 3
Sorry I'm replying late to this, Thierry - what you're trying
to do is indeed supported in Flex 2. We serialize Throwable types
as Beans (although we include read-only properties). If the client
does not have a matching ActionScript class registered with a
matching alias as the Java exception type, an anonymous Object will
be created with properties matching the "bean" properties. It seems
you've now worked out what the issue was while talking to
Seth.
Avatar
Level 3
Hi Thierry,
Things should work correctly if you compile your app using
the -compiler.external-library-path and -runtime-shared-libraries
options with mxmlc.
When you compile your app and don't give it any knowledge of
these classes tagged with [RemoteClass] metadata that you'll be
loading at runtime, you're correct that the registerClassAlias()
call won't be code-gen'ed.
Best,
Seth
