My husband downloaded an ebook to add to Adobe Digital Editions. I wanted to run it on my computer, however, I accidently typed in the wrong Adobe id into Adobe Digital Editions. Is there anyway that I can "deauthorize" my computer in order to put in the Adobe id that was used initially to purchase the ebook?
Thank you,
Annette
Ctrl-Shift-D (Windows)
Cmd-Shift-D (Mac)
Note: deauthorizing does not increase your activation count.
Very helpful--thank you so much, Jim!!
When and where do you use the Cmd=Shift-D command to deauthorize a computer?
Start Adobe Digital Edition then use:
Cmd-Shift-D (Mac)
to Deauthorize ADE
Then enter your new authorization ID.
I have done this but it keeps saying try again later...literally. I know my password is correct as I have checked it. Any suggestions?
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Mac: Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
ADE will be deauthorized now.
Now Authorize ADE again.
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
Reference:
Error "E_AUTH_NOT_READY" | Digital Editions
Hope this works !!
