CFSelect Problem
Aug 07, 2006 Aug 07, 2006
I am having a problem with CFSELECT (w/ in a FLASH FORM) and SELECTED.
The query that populates the drop-down select box is:
<CFQUERY NAME="GetUsers">
select last_name || ', ' || first_name as uname
from users
</CFQUERY>
Example: uname= Doe, John
The query that the form uses is:
<CFQUERY NAME="GetDetail">
select id, type, name
from activities
where activity_id = '#URL.ID#'
</CFQUERY>
Example: name = Doe, John
The CFSELECT:
<cfselect name="user" query="GetUsers" display="uname" value=uname" label="User Name:" queryPosition="below" selected="#GetDetail.name#"><option value="">Select a Name</option> </cfselect>
The problem is that the CFSELECT is deliminating by the comma and separating the first, last names into multiple fields which do not match the SELECT value.
I need to be able to format the names in this manner any suggestions on how to accomplish the use of the CFSELECT with a comma in the name?
Thanx
Mike
Advanced techniques
512
Participant ,
select last_name+', '+first_name AS uname
seems to work ok
couldn't even get || ', ' || to work...? using msSQL2000
Aug 08, 2006 Aug 08, 2006
The bars "||" work fine in Oracle for concatenating two fields together in the SQL. The problem I am having is in displaying the field that has a comma in the data in the CFSELECT.
Thanx anyway.
Participant ,
try this....
use tilde "~" or something weird as deliminator in query
replace in select -option... don't know if will work in cfselect because the variable is not ##'ed
My suggestion is to not store the user's name in your activiities table. Store the user_id, instead. Then you can use the user_id field, which is hopefully numeric, in your cfselect and you won't have any problems with commas.
Documentation
