1. Re: Save multipage PDF into separate pages as PDF files
(Miles_Rosen) Jan 14, 2008 4:21 PM (in response to (shivajiv))did you ever get an answer on this? I'm trying to find out the same thing, so if you know, please help me -
2. Re: Save multipage PDF into separate pages as PDF files
(Deena_Youssef) Feb 24, 2008 1:30 PM (in response to (shivajiv))Document > Pages > Extract3 people found this helpful
Specify which pages to extract
Press OK
Pages you specified will appear in a new document
You can save this under a new file name
This is all in the help section..search for 'extract pages' -
3. Re: Save multipage PDF into separate pages as PDF files
(Jason_Yord) Dec 7, 2008 1:49 PM (in response to (shivajiv))I have the new Acrobat Reader 9.1 person found this helpful
When I go to Document I don't have "Page" feature.
So I cannot separate the pages.
What do I do? -
4. Re: Save multipage PDF into separate pages as PDF files
rcraighead Mar 14, 2009 7:54 AM (in response to (shivajiv))I used this method to extract pages from a Illustrator CS4 file and they appear as single pages in Acrobat, but when opened in AI, all pages are still in each file. I'm looking for a simple way to export individual pages from an AICS4 multi-page PDF. -
5. Re: Save multipage PDF into separate pages as PDF files
scottvk1965 Feb 18, 2010 12:12 PM (in response to (Jason_Yord))I am using Acrobat 8.0 I don't have a "pages" either. But you should see "Extract Pages" under the Document drop-down list. It work perfect for me and saved a lot of time. Glad that Adobe had the foresight to build in this function.
6. Re: Save multipage PDF into separate pages as PDF files
Stewart_Macarthur Apr 27, 2010 8:37 AM (in response to (shivajiv))1 person found this helpfulI have Acrobat 9. When I click on the ‘Document’ option in the toolbar, I click on ‘Extract Pages’. It then asks me to specify what pages I want to extract and gives me 2 check box options. The first asks if I want to delete the pages after I extract and the second gives me the option to extract each page to an individual file.
Hope this is helpful to someone... :o)
7. Re: Save multipage PDF into separate pages as PDF files
monkeyspankin Jun 3, 2010 11:53 AM (in response to (shivajiv))AWESOME!!!! This thread was exactly what I needed. I split a single 8 page pdf into 8 separate pages.
Well done!
8. Re: Save multipage PDF into separate pages as PDF files
optaira espejo Jul 2, 2010 1:52 PM (in response to (Deena_Youssef))1 person found this helpfulThis worked perfectly. Only one thing, if you open the pdf on ilustrator again all the pages will still appear, to avoid that make sure you unchecked the "preserve illustrator editing capabilities" before saving your illustrator file into pdf.
Hope it helps
9. Re: Save multipage PDF into separate pages as PDF files
optaira espejo Jul 2, 2010 1:53 PM (in response to rcraighead)2 people found this helpfulto avoid that make sure you unchecked the "preserve illustrator editing capabilities" before saving your illustrator file into pdf.
10. Re: Save multipage PDF into separate pages as PDF files
Ilene4 Aug 13, 2010 10:02 AM (in response to Stewart_Macarthur)Stewart,
When I specify what pages I want to save as individual pages, is there a way to name each page?
Ilene Young
11. Re: Save multipage PDF into separate pages as PDF files
Math_Nerd13 Aug 30, 2010 12:38 PM (in response to (shivajiv))I am on Reader 9.3 and I don't see pages or extract pages under documents. Is it because we only have Adobe Reader and nothing else?
12. Re: Save multipage PDF into separate pages as PDF files
monkeyspankin Aug 30, 2010 4:43 PM (in response to Math_Nerd13)You need any of the Adobe Acrobat products; not Adobe reader. Adobe Reader is the free lighter version of Acrobat from Adobe without all the bells and whistles of Acrobat. I used Acrobat at work to break my pages since I too have only Adobe Reader at home. Yeah it sucks I know. You might try the library, work, etc.for a computer with Acrobat. You can pick it up pretty cheap on ebay or craigslist.
13. Re: Save multipage PDF into separate pages as PDF files
bsnyder02 Sep 15, 2010 7:22 AM (in response to (shivajiv))I was able to accomplish this using a free online service called www.splitpdf.net. You simply upload the file and tell it which page you want extracted. It then returns a pdf containing only the page you selected. Unfortunately, you have to repeat this step for each page you need to extract but it's an easy process.
14. Re: Save multipage PDF into separate pages as PDF files
Ilene4 Sep 16, 2010 12:20 PM (in response to bsnyder02)Thank you so much for this information. I will definitely use it on my next report.
Ilene
15. Re: Save multipage PDF into separate pages as PDF files
Vigorkk Feb 15, 2011 6:13 PM (in response to (shivajiv))I don't have Acrobat,too. I don't think it is convenient enough to split PDF pages, see you have to find the page you need then extract it repetitively one by one. To split PDF into single page, I think there is also a better program. A smart PDF splitter will take you out of painstaking manually splitting.
It will do the rest for you automatically.
16. Re: Save multipage PDF into separate pages as PDF files
KLucero Jun 21, 2011 2:53 AM (in response to (shivajiv))Using Acrobat 10, simply click View > Tools > Pages > Extract to quickly produce the single page files you need.
17. Re: Save multipage PDF into separate pages as PDF files
Ilene4 Jun 21, 2011 5:06 AM (in response to KLucero)Thank you, everyone, for all your responses. I've have it so it will work now. I appreciate your help.
18. Re: Save multipage PDF into separate pages as PDF files
bigjake1 Sep 15, 2011 11:39 AM (in response to (shivajiv))I found a much faster drag and drop option that allows you to split up a pdf document, by dragging a page or multiple pages into any folder you want... so much faster!
I'm using Adobe Acrobat Pro 9:
-Go to View--> Navigation Panels--> Show Navigation Pane (The navigation pane should pop up on the left hand side, and shows small tiles of each page in your pdf).
-Now select the Hand Tool (it looks like a white glove)- located in the menu at the top (if you don't see it, go to View--> Toolbars--> Select and Zoom and it should appear in the toolbars at the top).
-With the Hand Tool activated you can grab a page from the navigation panel and drop it into any folder or onto your desktop; to grab more than one page, click in the grey area surrounding the small tiles and you can drag over more than one, also try using the shift key to highlight pages that aren't side by side.
Hope this helps!
PS: You can do this on a mac computer without using Adobe; its a built in feature of the document preview software that comes on macs.
19. Re: Save multipage PDF into separate pages as PDF files
Ilene4 Sep 15, 2011 11:43 AM (in response to bigjake1)Thank you so much. This is exactly what I needed. Thank you for responsding.
20. Re: Save multipage PDF into separate pages as PDF files
jaegow Oct 17, 2011 9:15 AM (in response to (shivajiv))1 person found this helpfulIn Adobe Acrobat Pro 10:
1.) Open your PDF
2.) Select Tools/Pages/Split Document
3.) Split your document by one page in the Number of Pages section
21. Re: Save multipage PDF into separate pages as PDF files
Ilene4 Oct 17, 2011 9:31 AM (in response to jaegow)Thank you. I appreciate everyone’s help with this issue. I am able to split my pages now.
Have a great day!!
22. Re: Save multipage PDF into separate pages as PDF files
RooksGambit Oct 21, 2011 5:58 AM (in response to (shivajiv))1 person found this helpfulI need some help form anyone who knows...175 page document. Each page is single report for a person (different person each page) and that persons name always appears in the same spot at the top of the page, right below the title.
I'd like to split the document into 175 PDFs AND have each filename contain the persons name. Can this be done using Acrobat Pro 9? If so, how?
23. Re: Save multipage PDF into separate pages as PDF files
j.doug.turner Dec 22, 2011 9:18 AM (in response to RooksGambit)Did you get an answer to this question? I have a similar situation
Doug Turner
24. Re: Save multipage PDF into separate pages as PDF files
j.doug.turner Dec 22, 2011 9:27 AM (in response to j.doug.turner)Ok - I think I found an answer. You wan to "Split Document" rather than extract page. If you are using Acrobat 9 - go to document Menu and come down to Split document. You can make it 175 pages, 1 page at a time. In fact, if you have entered Employees Names (in your example) as booknarks, you can name each of the files after the employee. Email me if you have a problem douglas.turner@me.com.
25. Re: Save multipage PDF into separate pages as PDF files
SC201 Jan 9, 2012 10:32 PM (in response to (shivajiv))I discovered another way (I have the trial version of Adobe Reader) to split pages if you only want a few of them. You open your multipage document and then go to the top of the menu where it says "View." Click on "Two Page View." Now scroll to the page you want to separate. Then go to "Edit" and click on "Take a Snapshot." Click on the page you want to separate out. It will tell you that "The page has been copied." Now paste it into a Word Document and save it as a PDF.
It's complicated but it works.
26. Re: Save multipage PDF into separate pages as PDF files
Naidu26 Mar 1, 2012 3:02 PM (in response to bsnyder02)wow thank u macho it really helped me a lot...kudos
Onces again 'Thank U' so much...
27. Re: Save multipage PDF into separate pages as PDF files
AlROEMY Apr 12, 2012 7:40 AM (in response to (shivajiv))Another great way in Acrobat Pro, is using the "Document" -> "Split document" function, where you can specify how big the files should be, or how many pages each file should contain.
Just had a specific case, whit 176 pages, that needed to be split into 4 pages per pdf - took 10 sec.
28. Re: Save multipage PDF into separate pages as PDF files
Razi121 Sep 27, 2012 6:23 AM (in response to AlROEMY)In Acrobat X Pro, split multiple files once using above mentioned feature:
Tools Pane -> Pages -> Split Documents
29. Re: Save multipage PDF into separate pages as PDF files
bolton_schoolteacher Nov 11, 2012 2:46 AM (in response to Razi121)Here is how I did it very easily in Acrobat X Pro on a Mac:
1. Open the document to be split into separate pages.
2. Select: Tools / Pages / Extract.
3. Enter the page range to be separated.
4. Check only the box 'Extract Pages As Separate Files' and OK.
3. Select a destination folder and click 'Choose'.
Job done.
30. Re: Save multipage PDF into separate pages as PDF files
rwhsppt Feb 12, 2013 11:57 AM (in response to (shivajiv))If you are using Adobe Reader and you have a mac, you can extract each page using Preview. Make sure the sidebar is visible, select the page you want to delete (in the sidebar) and choose Edit > Delete Item.
I haven't found a way to do this on a PC using Adobe Reader.
31. Re: Save multipage PDF into separate pages as PDF files
Kiran30 Feb 13, 2013 10:34 PM (in response to rwhsppt)If you have just Adobe reader, then best way is to open the pdf in Google Chrome.
First, Make sure you have enabled Chrome PDF viewer extension
Open PDF in chrome
Right click the page and select print
On the print dialog that comes up, change the destination to “Print to PDF”
Now instead of selecting All radio button to print/save all. Select your page range and then print.
Note this will work with PDF's that are compatible with Chrome
hope this is helpful.
32. Re: Save multipage PDF into separate pages as PDF files
rstock Oct 25, 2013 8:14 AM (in response to bigjake1)Your solution on how to drag a page or multiple pages into any folder worked really well the 1st time I tried it. Now I am trying to do it again & it is not working. Additionally, I am using Adobe 9 Standard Version -- could this be the problem. I have no choice in the version of Adobe as this is the one they have at my office. Can someone please tell me how to drag multiple pages into any folder on my computer even if the pages are not sequential? Post 18. bigjake1 – was so helpful, but it does not seem to be working with Adobe 9 Standard. I am operating on a PC not a MAC
33. Re: Save multipage PDF into separate pages as PDF files
rstock Oct 25, 2013 12:16 PM (in response to bigjake1)I'm trying to etract 2 non-adjacent pages in a pdf to create a new pdf file. I am running Adobe 9 Standard. Can anyone please help?
34. Re: Save multipage PDF into separate pages as PDF files
Valley_Guy44 Mar 12, 2014 1:36 PM (in response to Kiran30)Incredible. So easy - thank you!!!
35. Re: Save multipage PDF into separate pages as PDF files
Melissa RL Jun 5, 2014 6:46 PM (in response to KLucero)I am very frustrated as I do NOT have Documents, Pages or Extract in Adobe Reader XI.
I have looked everywhere and simply exhausted the options and the tools menu is nil.
I only have File, Edit, View, Window and Help and there is no option within these to split/extract a document.
Any help on this would be appreciated.
thanks
Melissa
36. Re: Save multipage PDF into separate pages as PDF files
ducktape74 Jun 10, 2014 12:33 PM (in response to Melissa RL)In Acrobat XI click on "tools" (right hand side next to "sign" and "comment").
Under "manipulate pages" is an option "extract".
You can select which pages to extract and how to process them.
37. Re: Save multipage PDF into separate pages as PDF files
Lisa Hinkson Jun 15, 2014 1:30 PM (in response to (shivajiv))I am very frustrated as I do NOT have Documents, Pages or Extract in Adobe Reader XI. (same exact problem as Melissa)
thanks
Lisa
38. Re: Save multipage PDF into separate pages as PDF files
Lisa Hinkson Jun 15, 2014 1:37 PM (in response to Melissa RL)Melissa,
Did you ever figure out how to save separate, specific pages from a PDF file? It seems the only way I can do it, is be forced to purchase subscription from this company! Really upset I downloaded newest version.
I was doing fine with the old one and I did not have to buy anything!
