Hello!
I've created a webservice that reads a value from a database using this SQL statement:
SELECT ID from sequencias WHERE ( ref = {$ /process_data/@refFormulario$});
This just returns a number (in a string output variable) to the form.
Now I need to concatenate a slash and the current year. So if the the number is, say, 345, I need to add "/2011".
Question: should I add another Task or is there a way of using a string function (like Concat) to do this?
And... how do I do it? I've tried to use concat when building the Data mapping, but it did not work.
Thank you for any hints!
Marcos
Solved! Go to Solution.
Total Likes
Option1 :
You can concatenate this string in the SQL statement itself which is faster than any other options below.
Query (for Microsoft Sql Server database)
Query (for MySql database)
Option 2:
Concatenate the result string from web service using a SetValue activity at the end of web service workflow.
Assignment:
Assuming that the output variable name is "result"
Option 3:
After the data gets populated in the form field, you can change through either JavaScript or FormCalc.
Nith
Total Likes
Option1 :
Option 2:
Assignment:
Option 3:
Nith
Total Likes
Hey Nith!
Thank you very much, once again!
I used the Workbench solution, worked perfectly!
Thank you!
Marcos
Total Likes
