Generate Shared Secret ?
Guest
Jun 20, 2011 Jun 20, 2011
I am creating service in C# wich creates new Distributor , i could not generate Distributor Shared Secret for distributor being created. Can anyone tell what is the formula for Generating Shared Scret ?
1.4K
Enthusiast ,
A shared secret is 20 bytes of binary data.  I would suggest using random data...  (and it is base64 encoded in the XML)
Guest
Thanks Jim,
Here is my c# code for creating distributor:
Xml:
<request action="create" auth="builtin" xmlns="http://ns.adobe.com/adept">
  <nonce>rNfAkgAAAA4=</nonce>
  <expiration>2011-06-20T12:07:58-00:00</expiration>
  <distributorData>
    <name>Shafqat</name>
    <distributorURL>http://www.shafqat.com</distributorURL>
    <notifyURL>http://www.shafqat.com/notify</notifyURL>
    <description>description shfqat</description>
    <maxLoanCount>9</maxLoanCount>
    <linkExpiration>19</linkExpiration>
    <sharedSecret>Q1nKX1RjimoVy5jzayWcYXe4xuU=</sharedSecret>
  </distributorData>
  <hmac>8SnrEtwNnDoXF4r4e0g8y27fveo=</hmac>
</request>
C#:
            HttpWebRequest request = (HttpWebRequest)HttpWebRequest.Create(new Uri("http://192.168.0.61:8080/admin/ManageDistributor"));
            request.Method = "POST";
            request.ContentType = "text/xml";
            StreamWriter writer = new StreamWriter(request.GetRequestStream());
            writer.Write(Encoding.UTF8.GetBytes(xml));
            writer.Close();
            HttpWebResponse webReaponse = (HttpWebResponse)request.GetResponse();
            StreamReader reader = new StreamReader(webReaponse.GetResponseStream());
            Response.Write(reader.ReadToEnd());
            reader.Close();
i could not get anything in response and niether distributor is created ? can you guess whats wrong with code?
Thanks, Shafqat.
Enthusiast ,
Jun 21, 2011 Jun 21, 2011
With no response at all I would suspect that your handling of the HTTPWebRequest class is off.  What happens when you use curl to do a post?
Guest
Thanks Jim,
I am not using CURL. This is simple asp.net/C# (.net framwork 4.0) code. When i execute that i gives error about content type. Invalid content type.
Enthusiast ,
Jun 22, 2011 Jun 22, 2011
Oh so you are getting a response.  I had noticed that you are setting the Content-Type to 'text/xml' instead of the correct value "application/vnd.adobe.adept+xml" - you will want to fix that.
Guest
Jim i am very thankful to you for your quick response to my questions. My problem have been soleve .  it was a problem with generating hmac. i have got the solution. If anybody interested in C# version of UploadTool i will send the source code to him........
Thanks.
