I'm trying get FB 4.5 to installation in silent mode ( on Win 7 64bit ) using the Adobe Application Manager Enterprise Edition. Installed the tool on Win 7 box, and rattled through Dreamweaver, InDesign, and several others without incident. When I got to FB 4.5, nothing that I try seems to work. I set up MSI logging and it I get the following at the very end of the log - and its conisistant, regardless of what I've tried.
Action ended 9:20:23: PublishFeatures. Return value 1.
Action start 9:20:23: PublishProduct.
Action ended 9:20:23: PublishProduct. Return value 1.
Action start 9:20:23: InstallFinalize.
CustomAction CADeploy returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 9:20:50: InstallFinalize. Return value 3.
Action ended 9:20:51: INSTALL. Return value 3.
MSI (s) (24:70) [09:20:51:110]: Product: Adobe Flash Builder 4.5 Silent -- Installation operation failed.
MSI (s) (24:70) [09:20:51:110]: Windows Installer installed the product. Product Name: Adobe Flash Builder 4.5 Silent. Product Version: 1.2.0000. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
=== Logging stopped: 6/23/2011 9:20:51 ===
---- END of Log ----
Any suggestions on how to get this one to deploy in silent mode?
Thanks... TP62
Hello,
I have the same issue when trying a silent installation of Flash Builder 4.5.
In fact, when I launch the following command :
msiexec /i "E:\FB4.5\Flash Builder 4.5\Build\Flash Builder 4.5.msi" /norestart /quiet /log "E:\tmp\softs\logs\install-flash-builder-4.5-20110711.log"
The instllation stops strangely and I have the following message in the end of the log file :
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): ProductToBeRegistered = 1
MSI (s) (E4:A4) [15:28:49:300]: Product: Flash Builder 4.5 -- Installation operation failed.
Can you help please ASAP ?
Best regards,
Riadh
Where are you getting an MSI? The installer I got for FB 4.5 is an .exe, and it's contents do not include any MSIs.
