I want to attach files like .doc, .xls, .pdf. etc in my Design editor, instead of importing those files. Is there any way to do that. Please help.
Vinay Jaassiel Kankipati
Technical Writer
Hello Vinay
I'm not sure I totally understand what it is you wish to do. Are you saying you want to open these files and see their contents in the RoboHelp editor?
Perhaps it would help if you assume we are someone quite new and you are trying to explain how to accomplish what you want assuming that things worked exactly as you wanted. For example:
Open RoboHelp
Open a Topic for Editing
Click here
Do this
Do that
Now do the other
My thought is by knowing how you are expecting to operate that we might better advise as to whether it's possible to achieve. If so, how you might accomplish it.
Cheers... Rick
As I clearly mentioned last time that I want to ATTACH the files in WYSIWYG and NOT IMPORT the contents of the files in WYSIWYG. For everyone's understanding I have inserted this image. When I attach files I want them to be displayed like this. So, when the WebHelp is generated, these files should look exactly the same and if double-clicked, they must open.
V!ñ@¥
It may have been clear to you but Rick's reply indicated it wasn't clear to him and I have to say it wasn't clear to me either. You attach files to emails but not to web pages including help topics, there you link to them, hence your question not being entirely clear
In help topics you create links to such files and the link can be text or an image. You would have to use images such as those posted.
Bear in mind that you have no control over what will happen when the user double clicks the link. Documents may open in their browser or in the application. That depends on their browser and the settings. You cannot force it.
Also any linked document may be searchable depending on your version of RoboHelp. Please see the forum sticky topics and in particular Before You Post. It helps with replies when we know what version of RoboHelp you are using.
Hi Vinay.
Would these files be editable and if so, where would they reside? If you want people to be able to edit the files, you need to consider where the files are located. If you link directly to a file in RoboHelp, a local copy is copied into your project as a baggage file. If a user then clicks on the link, the local copy is opened and any edits can not be saved back to the WebHelp's output location. However if you were to create an image (like the ones you used above) and added a hyperlink to the file's location - i.e. on a network drive outside the project, this would enable users to edit and save changes to the original file location. Hope this helps.
The RoboColum(n) | @robocolumn | Colum McAndrew |
Colum
Have things changed as otherwise I believe the files will not necessarily open in their native application for editing?
Hey Peter. You are WebHelp king so I bow in your general direction. I think I'm thinking of CHM files.
I have just done a quick check and it looks like how things have changed if you have Vista / Windows 7 and a later browser. What is likely to happen there is that the user will be given the option to open the document or save it. If they save it, they could then miss later changes.
Prior to that, what happened was a user setting as in Snippet 22 on my site.
I have only tested this with a document that was added to baggage files.
See also http://support.microsoft.com/kb/162059
Vinay
It would be nice to know if the additional information has helped you.
Hi Peter,
Sorry for coming back late into this. I tried your option where I inserted an image of the file and then linked it to the respective file. When I try to open it, it's asking to OPEN or SAVE and whatever option I click, it's working fine. But now the problem is, the image shows a constant file name that doesn't reflect the actual file that is being opened. Is there any way to solve this problem.
Vinay
The image shows the file name permanently or just when you hover over it?
Please add a screenshot using the camera icon you will see when you reply.
For example, I am linking an XLS file called "Report.xls". I have to create an image from that particular file only, something like this:, insert the image in RH and then link it with the XLS fle Report.xls.
If I have to link another XLS file called "Schedule.xls", then I have to create another image for this file like and do the whole process of inserting and linking again.
So, I wanted to know if there is a solution for this situation.
Hi Vinay
To my knowledge there is no way to dynamically change the image name to reflect what it is linking to. I might suggest cropping out the file name and leave the icon only.
Cheers... Rick
As this is the only solution for my problem (not an easy one though), I will go with it.
Thanx all for sharing your views.
