SOAP parameter serialization
Avatar
Level 2
Hi all,
I'm looking for some information on how Flash/Flex serializes
parameters to WebService operations. If a web service operations
takes a simple parameter like a string, I can just pass it in as
the argument to the Operation.send() method but what if the
parameter is a "complexType"? Do I need to create an xml node or
just an object with public properties, etc...?
Any info on this would be much appreciated.
Ryan
Avatar
Level 3
Hi
For complex type you can pass the parameter in object. for
example:
WSDL type definition
<complexType name="SOAPStruct">
<sequence>
<element name="varString" nillable="true"
type="xsd:string" />
<element name="varInt" type="xsd:int" />
<element name="varFloat" type="xsd:float" />
</sequence>
</complexType>
_service.echoStruct({varString:'The String', varInt:245,
varFloat:2134.123});
or pass it through from tag declarion: for example
<mx:operation name="echoStruct" result="onResult(event)"
fault="onFault(event)">
<mx:request format="object">
<inputStruct>
<varString>The String</varString>
<varInt>245</varInt>
<varFloat>2134.123</varFloat>
</inputStruct>
</mx:request>
</mx:operation>
and you can also construct it as xml, for example
<mx:request format="xml">
<ns1:doGoogleSearch xmlns:ns1="urn:GoogleSearch"
xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance">
<key
xsi:type="xsd:string">00000000000000000000000000000000</key>
<q
xsi:type="xsd:string">{ti_searchparm.text}</q>
<start xsi:type="xsd:int">0</start>
<maxResults xsi:type="xsd:int">10</maxResults>
<filter xsi:type="xsd:boolean">true</filter>
<restrict xsi:type="xsd:string" />
<safeSearch
xsi:type="xsd:boolean">false</safeSearch>
<lr xsi:type="xsd:string" />
<ie xsi:type="xsd:string">latin1</ie>
<oe xsi:type="xsd:string">latin1</oe>
</ns1:doGoogleSearch>
</mx:request>
Hope the above info help! Thanks!
William Chan
Avatar
Level 2
William - Thank you, this is helpful. One other thing
though.. a few of the web service operations I need to call have a
parameter defined like this:
<complexType name="Account">
<sequence/>
<attribute name="Name" type="string" use="required"/>
<attribute name="Value" type="string" use="required"/>
</complexType>
Notice that the Name and Value items are attributes, not
sub-elements. If I create an object like:
var param:Object = {Name:"xxxx", Value:"yyyy"};
is there a way to have these properties encoded as attributes
as opposed to sub-elements?
Ryan
Avatar
Level 3
Ryan - you can just pass the object, flex does take care
where it is element or attribute
following is the sample(one of testcase we have)
<s:complexType name="Person">
<s:sequence>
<s:element minOccurs="1" maxOccurs="1" name="Age"
type="s:double" />
<s:element minOccurs="1" maxOccurs="1" name="ID"
type="s:float" />
</s:sequence>
<s:attribute name="Name" type="s:string" />
<s:attribute name="Male" type="s:boolean" />
</s:complexType>
var expected:Object = new Object();
expected.Name = "Bob Smith";
expected.Male = true;
expected.Age = 31;
expected.ID = 12345;
operation.send(expected);
