When using Flash Builder eclipse plug-in Version 4.0 (build 272416), we are able to digest the Data/Services of a BlazeDS enabled server. The ActionScript generator dynamically connects to the BlazeDS server, and then generates the necessary ActionScript. Another developer happened to download their Flash Builder a few weeks later 4.0.1 (build 277662) and is getting the following error when attepting to digest the Data/Services:
ActionScript generation is not supported for entities containing properties or methods that clash with ActionScript keywords. Entity "MapLink" contains illegal property "to".
Indeed, the error message is correct; Our MapLink object does have an attribute "to". However, we have no ability to change this attribute!
So my question is: Is there a way to configure the ActionScript generator to ignore this rule? Or is there another work-around for this (other than roll all the developers back to the 4.0 version of Flash Builder)
I have the same error with defferent phrase :
ERROR [1]: ActionScript generation is not supported for entities containing properties or methods that clash with ActionScript keywords. Entity "CachedClass" contains illegal property "void".
It happens when i try to digest a groovy entity (domain class) using the BlazeDS. Did any one resolve this issue ?
No, the issue was not resolved. Since it was a temporary project (short lifespan) we just cloned the 4.0 environment for anyone that happened to get the 4.0.1 load.
