3 Replies Latest reply: Jun 26, 2011 2:35 PM by J4e8a16n RSS
    exporting video quicktime h.264 from .avi has no sound
    J4e8a16n Community Member
      I am on CS4 extended.
      I am trying to export an avi video to a quictime h.264 video and I have no sound.
      Although I did that  and having sound, I dont know why it stopped suddenly.
      I  recorded something in the same time with cam studio. May be that's why.
      So I shutted down the computer and  reopened it.
      Same problem.
      Someone has a clue?
      Thanks for your attention,
      JP
        • 1. Re: exporting video quicktime h.264 from .avi has no sound
          Bill Hunt CommunityMVP
          JP,
          I do not have my CS5 Extended handy, so will go from the Premiere Pro (Adobe's video editor) side of the street. Bear with me on this, as PS-Extended might do things a bit differently.
          When one is Exporting an AV file, there are two things that must be set:
          Exporting both Audio & Video (in PrPro, these are done via checkboxes in the Export>General dialog screen)
          Then, one must set Multiplexing * on the Export>Multiplexing dialog screen, to anything but "None." The choice is usually "DVD."
          It's the Multiplexing Tab, that many miss. If set to None, then there will be two separate Export files - one for the Video stream, and one for the Audio stream.
          Hope that gets you close, and sorry that I cannot open things up, and give you the exact screens and tabs in PS-Extended.
          Hunt
          * Multiplexing is the combining of both the Audio & Video streams into a single, discrete file. Multiplexing is usually OFF by default, though in PrPro, it's a "sticky," in that it retains the last setting, so if the user wishes to make a change, they must do so manually, and that setting will then stick, until changed again. The Export of separate files for Audio & Video is most often used, when one is doing the Export to go to a DVD, or BD authoring program, like Adobe Encore. It works best with elemental streams, rather than muxed files, and especially with MPEG Audio.
          • 2. Re: exporting video quicktime h.264 from .avi has no sound
            It seems the test.avi file play the soundtrack  with irfang view but not
            with cs4  even if I toggle the speaker.
            • 3. Re: exporting video quicktime h.264 from .avi has no sound
              OK.  I found there is two speakers, one on the time line, one on the play
              line to enable. I have sound in photoshop but the export command still
              produces video with no sound.
              JP
