Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Web Services Error
Avatar
Level 2
Hello,
Trying to do webservice and running into error message. Not
sure what I'm doing wrong. I'm trying to access a database and
display the content of the database into a datagrid. Can some
please help.
Here are the code
Simple.cfc
<cfcomponent>
<cffunction name="returnquery" access="remote"
returntype="query">
<cfset var qBikeParts="">
<cfquery name="qBikeParts" datasource="Error">
SELECT * from ErrorLog
</cfquery>
<cfreturn qBikeParts>
</cffunction>
</cfcomponent>
My MXML code
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
layout="vertical">
<mx:WebService id="myService"
wsdl="
http://www.Hawaiihotels.com/WSTest/Simple.cfc?wsdl"
load="myService.getData();"/>
<mx:DataGrid
dataProvider="{myService.getData.lastResult}"/>
</mx:Application>
This is the error message I get when I try to runn the
application
[RPC Fault faultString="Couldn't find method 'getData' in
service." faultCode="Client.NoSuchMethod" faultDetail="null"]
at
mx.rpc.soap::Operation/mx.rpc.soap:Operation::createFaultEvent()
at mx.rpc.soap::Operation/
http://www.adobe.com/2006/flex/mx/internal::invokePendingCall()
at mx.rpc.soap::Operation/send()
at Function/
http://adobe.com/AS3/2006/builtin::apply()
at mx.rpc.soap.mxml::Operation/send()
at Function/
at mx.rpc::AbstractService/
http://www.adobe.com/2006/actionscript/flash/proxy::callProperty()
at Database/__myService_load()
at
flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.rpc::AbstractService/dispatchEvent()
at mx.rpc.soap.mxml::WebService/dispatchEvent()
at mx.rpc.soap::WebService/
http://www.adobe.com/2006/flex/mx/internal::wsdlHandler()
at
at mx.rpc.soap::WSDLParser/dispatchEvent()
at mx.rpc.soap::WSDLParser/::parseCompleted()
http://www.adobe.com/2006/flex/mx/internal::httpResultHandler()
at
at mx.rpc::AbstractInvoker/
http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()
http://www.adobe.com/2006/flex/mx/internal::resultHandler()
at mx.rpc::Responder/result()
at mx.rpc::AsyncRequest/acknowledge()
at ::DirectHTTPMessageResponder/completeHandler()
at
at flash.net::URLLoader/flash.net:URLLoader::onComplete()
Does anyone know what I'm doing wrong, or how to resolve
this?
Jimmy
Avatar
Level 3
Hi Jimmy,
The error indicates that the WSDL can't be fetched and loaded
by Flash. Make sure
http://www.Hawaiihotels.com/WSTest/Simple.cfm?wsdl
is accessible in a browser, and if your swf is not being served
from that domain you will also likely need to host a
cross-domain.xml file at www.Hawaiihotels.com/ to allow Flash
clients access.
Best,
Seth
Avatar
Level 2
I just checked and was able to view the
http://www.hawaiihotels.com/WSTest/Simple.cfc?WSDL
from my browser. I am running the test from my PC, on a different
subnet from the hawaiihotels.com subnet. Could that be the problem?
Jimmy
Avatar
Level 3
That looks like a different error message, and in this case
you're invoking getData() on the client but the CFC defines a
"returnquery" function. Try updating one or the other to make the
method name match?
Best,
Seth
Avatar
Level 2
Thanks for the quick reply. I'm still very new to flex. Since
my cfc is returnquery, what are my option for the flex side? I'd
pretty much copied and pasted sample codes from various websites
tutorial. Not sure what is need to do on the flex end.
Jimmy
Avatar
Level 3
Try myService.returnquery() rather than myService.getData().
Best,
Seth
Avatar
Level 2
Ok I'd changed it to returnquery(), and now I'm getting this
new error message
Error: Cannot assign operations into an RPC Service (WSDL)
http://www.adobe.com/2006/actionscript/flash/proxy::setProperty()
at Database/::_WebService1_i()
at Database$iinit()
at mx.managers::SystemManager/create()
at mx.managers::SystemManager/::initializeTopLevelWindow()
at mx.managers::SystemManager/::frameEndHandler()
Just wanted to make sure I have added the returnquery in the
correct spot
layout="vertical">
WSDL="
http://www.Hawaiihotels.com/WSTest/Simple.cfc?WSDL"
load="myService.returnquery();"/>
<mx:DataGrid
dataProvider="{myService.returnquery()}"/>
</mx:Application>
Avatar
Level 3
Sorry, the load attribute in the WebService tag expects an
event handler. So you'd need something along the lines of:
<mx:WebService ... load="handleLoad(event)" .../>
In a script block, define your handler:
private function handleLoad(event:Event):void
I haven't tried binding CFQueries to anything but you'll be
able to access the result of your call several possible ways:
1. myService.returnquery.lastResult
2. Register a result event handler for your WebService
instance - when you make calls you get back an AsyncToken that you
can add state to. This same token is available to you in your
result handler so you can link the async result up with the
original call.
3. You can add a responder to the token you get back from
your call. When a result or fault is returned from the server it
will be passed to the result() or fault() event on your responder.
Best,
Seth
Avatar
Level 2
Hey Seth,
Really appreciate all of your help. So I did what you were
sugessting and now getting a differnt error messgae. But first of
all is my flex code even correct?
Flex Code
layout="vertical">
<mx:Script>
<![CDATA[
import mx.collections.ArrayCollection;
import mx.rpc.events.ResultEvent;
[Bindable]
private var myData:ArrayCollection;
private function resultHandler(event:ResultEvent):void{
myData=event.result as ArrayCollection;
</mx:Script>
WSDL="
load="myService.getquery();"
result="resultHandler(event)"/>
<mx:DataGrid dataProvider="{myData}"/>
</mx:Application>
Error Message
at Database$iinit()
Jimmy
Avatar
Level 3
Hi Jimmy,
Take a look at my previous posting. I think you still need to
make that change to the load attribute of your tag. The load,
result and fault attributes of the tag expect a handler function.
So something like:
rather than
<mx:WebService ... load="load="myService.getquery();" ...
Best,
Seth
Avatar
Level 2
Hey Seth,
I've rewrote my cfc and flex code now based on what you had
suggested. Now I have everything compiled and executing, put I do
not get anything populated in my datagrid. Do you know what could
be the problem.
Here's the new CFC code
<cfcomponent>
<cffunction name="getData" access="remote"
returntype="query">
<cfquery name="ELogs" datasource="Error">
</cfquery>
<cfreturn ELogs>
</cffunction>
</cfcomponent>
Here's the New Flex code.
layout="vertical">
<mx:Script>
<![CDATA[
[Bindable]
myData = event.result as ArrayCollection
</mx:Script>
wsdl="
http://www.hawaiihotels.com/WSTest/Simple1.cfc?wsdl"
</mx:Application>
Jimmy
Avatar
Level 2
I got the code to work now.
What I did was change the dataprovider to
myService.getData.lastResult, and bam all the data came in.
Thanks for everything.
Jimmy
