Since the last upgrade (I got it last week a couple of days after I installed the program), it takes forever sometimes to open the simplest files. Up to 10 seconds to open a one-page file. More if the file is larger. This is really annoying, as I am opening files all the time. It doesn't help if I close the program after each file is printed, or leave it open and just closing the file. Anybody else experiencing this who knows what's happening?
Version 10.1.0.534
All my problems disappeared after the last update (10.1.1). All files open quickly!
Am I really the only one with this problem???
Here as well, PDF files open in browser takes between 30 seconds to 2 minutes depends on the browser.
Internet Explorer 9 is dramatically slow while opening the same in Chrome is faster, but yet really slow.
Adobe guys, please help ASAP!
I am NOT opening in browser, but in acrobat x.
I agree, ADOBE people, please help. I am getting grey-haired by this as I am opening hundreds of files a day!
This issue started immidiately after installing the last update: 10.1.0.534
I'm working with Windows 7 Ultimate SP1
Yes, right after the last update. I installed the program last Monday, but got the update on Thursday or so. Up until then it worked perfectly. Windows 7 Professional.
We have 200 employees, the majority of which need to open and print hundreds of pdf documents a day. They are all experiencing this severe slowness issue. At first I thought it was a network or server issue, then an antivirus issue, but I have eliminated those as possibilities which led me to this forum via a google search for acrobat issues.
This is a very severe issue! It has cut our employees' productivity in half and costing us $thousands per day! Adobe need to address this immediately!
I will attempt the solution proposed on other forums of rolling back to version 9, but that will take considerable time to do on 200 workstations and laptops. This update should have been much more thoroughly tested!
-RG
If I understand it right, as soon as you upgrade your license(s) from 9 to 10, your 9 licence(s) are no longer valid. Isn't this correct? So as I see it, we are all stuck with version 10...
No. That is not correct.
Most certainly NOT . It is most rude for adobe to come up with this and suggest people upgrade or use it when it made it MUCH WORSE and way to slow if it works at all. I wish there was a way to uninstall it and go back to a previous version but guess not. If anyone has discovered a way to uninstall the latest upgrade and go back to previous version PLEASE POST.
The same issue has occurred to me as well. I feel this is eminent at the opening of PDFs with Acrobat JavaScript.
I am wondering this happens in Adobe Reader 10.1 as well.
I also want Adobe to address this issue as soon as possible.
The slow performance when opening PDF files is a new issue since the last build of Reader X.
The previous build had no problems.
Doron
Reader and Pro both? I wonder where they got it wrong... Nobody at Adobe seems to be willing to answer this...
They do seem to be willing to collect our money though!
The below is an example which takes more than 30 seconds for executing a simple Acrobat JavaScript: app.launchURL:
http://www.openspc2.org/reibun/Acrobat8/javascript/app/028/sample/sample.pdf
(I am using Firefox 5.0)
In the case of other versions of Acrobat, by clicking the button, in a second or two seconds, I see Yahoo! Japan.
But in the case of Acrobat X(10.1 My computer is Vista Ultimate SP2), it takes more than 30 seconds until I see Yahoo! Japan.
Loading PDFs takes more time in Acrobat Pro 10.1 but at the same time executing Acrobat JavaScripts seems to be really problematic.
Same issue with X pro for me...very slow when opening documents..
Any update for this?
I can confirm that this is also an issue for me — ever since the recent update.
Not only is there this weird slowness, Acrobat X periodically crashes whereas it was previously stable.
Surely Adobe already knows about this stuff from the Improvement Program data it collects? What is being done about it?
I also experience that Acrobat X is really slow after the latest upgrade. I now have 10.1.0. Only remedy is to drag files to the program window instead of double-clicking. What is Adobe doing about this?? Also annoying with endless updates to fix safety issues in Acrobat.
Anyone have any updates on this?
I just installed Adobe reader x and if I click on a link to a PDF on a site I can take the kids to school pick them up, do their homework then go out for a meal before a one page PDF opens.
Strangely I can right click and save it in an instant.
As an aside can I uninstall it and go back to 9 until this is fixed (I'm losing the will to live)
Thanks McP
Try this in Reader: Go to Edit / preferences / general - then uncheck the box "Enable protected mode at startup" . My Reader X was doing the same thing and this cured it straight away. I haven't tried it in Pro but see no reason why it wouldn't work there too. I'm not sure where that would be located in Pro.
I would recommend against disabling Protected Mode as this is:
· One of the new features of Acrobat
· Protects your machine from embedded malware.
What I’d like to see is acknowledgement from Adobe that it is investigating this problem.
Further, if there’s something broken, could it also mean that Protected Mode is also broken?
I think we need a security researcher to have a look at what’s going on here.
Tried it, (yes I know I shouldn't but I made the pdf) this made no difference.
It's all right companies adding features, but when they stop the main program working...
Can anyone tell me an answer to my original query, can I kill this piece of junk (as no one from Adobe has an answer, yet!) and re install v9?
I added "Priviledged locations" on my computer and the local network,which will be exempt from enhanced security. This seems to work. But I think there should be a default setting that only applies enhanced security to files that are opened from other places than the local network.
I recently did the update to both AcroX and Reader. The first PDF file opens up quickly. Any second file takes a considerable amount of time--too much time. Mainly this happen when I am trying to open up files over my companys network (a small business server). I find that local files on my computer do not appear to be affected by this. If the file is opened up over the network, any additional files can be simply dragged into the opened acrobat program and they open without problems. However, that is not a solution. Where is the "Priviledged locations" at?
Edit/Preferences/Seurity(enhanced)
