We've been publishing with Robohelp 8 HTML into WebHelp for more than a year, and on my last publish, it looks like search has stopped functioning. If I search for anything, no topics are returned.
It appears my publish settings are the same and the correct index is being used. Anyone have an idea what would cause this? I have no idea where to even start looking to figure out what's wrong.
Does the search function inside the generated help? If so, it must be a server related issue. Try publishing to a different location if that is possible.
The RoboColum(n) | @robocolumn | Colum McAndrew |
Yes, it does appear to be functioning locally. I will speak to my developer about a new location and see if that's possible. I'll let you know what happens!
Thanks for the help.
Can you tell us what the problem was please? Helps others with the same problem.
It ended up being a browser issue. The search function in RH8 does not work at all in Google's Chrome. We recently installed Chrome on a lot of our machines, and it turns out that's the browser everyone was using when they reported issues. Go figure!
For the record: I have no problems at all with RH8 WebHelp and Google Chrome. Local WebHelp is a problem, but that's Google's fault.
Greet,
Willam
There is another thread on this where it was tracked down to the Google Frame add-on.
http://forums.adobe.com/message/3725969#3725969
