Previous Topic Next Topic links in Merged Projects
Jun 28, 2011 Jun 28, 2011
Hello,
I have followed the steps mentioned in Peter Grainge's website http://www.grainge.org/pages/authoring/merging_webhelp/merging_method_rh8.htm for merging projects. Except that I have 3 topics in the Parent project and I have not used the redirect in the first topic of the parent project.
The Previous Topic and Next Topic links do not work properly both in the parent project and I am unable to navigate to the child projects using them.
Deepti Korwar
817
Hi there
Those buttons are intended to work with something called a Browse Sequence. They don't traverse the TOC unless you design the Browse Sequence to do so. But in a merged setup as you have, I'd be very surprised to discover there was a way to coax them to work as you want.
Hmmm, in thinking about it, I'm guessing you might coax the behavior by creating redirect pages that point to the desired topics and placing those in the Browse Sequence.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
You cannot create a single browse sequence across all the projects. Rick's suggestion should work though.
In each project create a blank topic in the same way that I suggest for the parent topic. Put that at the end of the sequence and use a redirect to the first topic in the next browse sequence. As far as users are concerned, that should work as one sequence. It is not something I have tried but it should be OK. The time between topics might vary a little, you will have to test to see if it is acceptable.
You mentioned that you have three topics in your parent project. I hope you have avoided links between them and the child projects in either direction.
@petergrainge
Jun 29, 2011 Jun 29, 2011
Thanks Rick and Peter,
It is working fine. But it produces problems when I am re-using the topics across projects using the redirect method.
Here vcd in parent is actually as redirect to View Content Details of child2. So when I click next from vcd it jumps to View Newsletter of child3. I know that I am asking for too much but is there a workaround for this too?
@Peter :- I did not understand what you meant by avoiding links in the topics of parent project. Can you explain in more detail or direct me to a topic on this?
Thanks Again,
Deepti Korwar
Jun 30, 2011 Jun 30, 2011
So the link "vcd" is a redirect to a topic in Child 2 but it goes to the book in Child 3? If the redirect is correct, then there has to be more to this. They look to be a means of switching from one project's output to another but that is not needed in merged help. Clarification required.
If you create links between the parent and a child or a child and the parent in the source using the RoboHelp interface, they will break in the output. That is covered in my Merged Help topics. You can of course handcraft them but the whole point of the method I describe is to avoid that and the inherent risks.
@petergrainge
Jul 05, 2011 Jul 05, 2011
Yes Peter. "vcd" is a redirect to a topic in Child 2. I have used the script code that you have mentioned in our site. I want it this way, as I would be reusing a lot of information among the child projects.
You have topics in the parent and one of them is a redirect to a child two topic. What code is in the redirect of the topic?
If you click the redirect from child 3 VCD what happens?
Remember I did caution against having topics in the parent.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
