Hello all, I have a ddlist that is filled from xml data. On select I would like selection to appear in the list box. I am not able to figure this out, can somone supply me with some direction.
Solved! Go to Solution.
Total Likes
This simliest way is this script in the change:Event of the dropdown box:
Total Likes
Total Likes
That worked great. On a side note...is there something needed to get the a reset button to remove the data from the list box?
Total Likes
To clear the Listbox use:
Total Likes
Thanks much for the help. Still not able to clear the list box. Can you verify that I entered correctly?
<?templateDesigner expand 1?></subform>
<field name="ResetButton1" y="82.55mm" x="117.475mm" w="28.575mm" h="6mm" relevant="-print">
<?templateDesigner isResetFieldsObject true?>
<ui>
<button highlight="inverted"/>
</ui>
<font typeface="Myriad Pro"/>
<caption>
<value>
<text>Reset Form</text>
</value>
<para hAlign="center" vAlign="middle"/>
</caption>
<border hand="right">
<?templateDesigner StyleID apbx2?>
<edge stroke="raised"/>
<fill>
<color value="212,208,200"/>
</fill>
</border>
<bind match="none"/>
<event name="event__click" activity="click">
<script contentType="application/x-javascript">xfa.host.resetData(); ListBox1.ClearItems();</script>
</event>
</field>
Total Likes
The correct syntax is clearItems(); not ClearItems();
Total Likes
