In my project(s) there are numerous topics where I have one or more "related topics" that now use the Related Topics button to display a list. Previously these related topic(s) were either a single or a list of hyperlinks using "see also: ....." but I believed the Related Topics button to be a step forward.
However, if there is only one other related topic then it acts as a hyperlink!
Does anyone know if there is any way to encourage the popup to list a single item for selection rather than jump straight to the topic as I would like to employ a single user experience; not a text hypperlink for single and a button for multiple links.
Hi there
You can try amending the code as follows:
Select your Related Topics button in the design editor and change to the HTML view.
You should see two different areas listing object attributes.
Add the following line to each area.
<param name=flags value="1">
Don't be too surprised if you discover RoboHelp "helps you out" by rewriting the code. If it becomes annoying, you may need to resort to javascript to overcome that niggling little feature.
Cheers... Rick
Hi Rick, thanks for the tip.
Adding the code worked fine but fingers crossed RH doesn't become TOO annoying, if I have to resort to Javascript then I will be lost.
Cheers ...Steve
Hello again
If you have to resort to JavaScript, the thread linked below might be helpful.
Cheers... Rick
