I imported a PowerPoint presentation and added audio but when I preview it in Captivate, it stops at the end of the audio for each slide. I think it is because there are click boxes set up in between each slide. I'd like the slides to just continue on to the next slide based on the audio. So I think I need to delete those click boxes but I can't figure out how. Or do I need to fix it in PPT and re-import the slides? How do I do it?
Welcome to our community
Pretty simple. Click each slide in the film strip. Then look at the Timeline. You should see the Click Box object there. Click on it to select it, then press the Delete key.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Cheers... Rick
