Locked
FB 4.5.1 iOS packaging failed
Jun 29, 2011 Jun 29, 2011
Hi, I managed to sign PlayBook app successfully, but failed to sign iOS app. I uploaded correct .p12 certificate and distribution provision that I used in my xcode, input correct password, then I clicked on Finish button. I saw the message of "Packaging for Apple iOS. This may take several minutes", but it just hanged there at Packaging: (0%)... Anyone facing the same problem? Or anyone know the solution? Thanks in advanced.
regards,
SeasonW
677
New Here , Jul 01, 2011 Jul 01, 2011
On Mac OS X it says the certificate is invalid or something like that, I don't remember the exact words, and throws an alert window with the command line usage of ADT. I'm going to try this: http://forums.adobe.com/thread/867664?tstart=30 to see if the problem it's in the way I export the certificate to .p12.
Jun 30, 2011 Jun 30, 2011
Same thing happening to me. It just hangs at "Packaging". The certificate and mobileprovision files work fine when using Xcode, the apps are signed and installed correctly on the phone, but no progress so far when using Flash Builder (on a Windows machine at work, if that matters. I'll try installing Flash Builder on my Mac). Already checked if the App ID is correct, etc.
Yes, please do keep me update once you have tested the FB 4.5.1 for MacOSX. Thanks!
Wow, thank you very much! I managed to get it work on Windows FB. I just followed the method on the thread that you pointed.
I will be busy in next few weeks to test flash on iPhone and most probably will submit one or two app to check if Apple will reject flash app or not. Thanks!
