hi,
I have a CS Extension that compiles just fine. I can select "Debug as" and run it as an InDesign extension without any issues. When I am ready to export the extension to create a .zxp package using the "Export Wizard", I get an error "Selected Project did not compile". There are no errors listed.
Can you please tell me how to troubleshoot this further? Is there some logs that I can look at? I have InDesign, Photoshop, Illustrator components selected in my extension. I created a new certificate. I recreated my project from scratch and copied my source files over. Nothing seems to help.
thanks for any help.
Hi Rums,
Are you using Flash builder standalone or the eclipse plugin?
I've seen a problem like this before, the issue in that case was that the Flex compiler ran out of memory during the export build - if you haven't already, try increasing the ammount of memory you give eclipse. You can find out what file to change and what settings to use by taking a look at the Flash Builder readme file that sits alongside the Flash builder executable (so in C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.5 on windows or /Applications/Adobe Flash Builder 4.5/ on mac) - I just use the settings recommended there (search for "vmargs").
Louis
hi Louis
Thanks. I am using stand-alone Flash builder. I deleted my project and re-created it from scratch. It compiled this time with the same project files. This one still remains a mystery. Hope I don't run into it again.
thanks.
