I use flash builder 4.5.1 to build app for Google Maps API for iOS (map_flex_1_20.swc), and it is working well even on the simulator on PC, but after I generate the IPA use FB4.5.1, and install on iPad , it not working at all, only show a while screen.(I used the TabbedViewNavigatorApplication, the botton Tabbar is working, I can switch the page, but on the maps page show nothing)
I also try the code on Flash CS5.5 using map_1_20.swc , when on the PC debug, it works well,(swf files), but install the AIR ipa on the iPAD, show nothing only a white sceeen.
anyone met this problem?
I think there is no way to use the Google Maps API for Flash / Flex for iOS, because it tries to load an external swf file form the google server at runtime, and the iOS doesn't allow it. The only workaround I have found so far is create a web page with the Google Maps API for JS, and load it with StageWebView.
Cait Seth is correct.
-Anirudh
Thanks for this workaround.
Argh, I was afraid of this...
With AIR 3.0 and native extension, you can use google Maps native component to display maps on your AIR application. Check out http://code.google.com/p/air-maps-ane/ for some basic mapping functionalities.
You can also use the MapQuest Mobile Flash Maps API. It's supported by MapQuest and does not need any work-arounds in order to work with the Flash Platform. It also takes advantage of the "build once, deploy anywhere" functionality in Flex 4.5+. MapQuest provides a demo app for Android and iOS and has the source code available for download, too.
