2 Replies Latest reply: Jul 9, 2011 8:42 AM by Shane P RSS
    r6025 error when inporting sequences.
    Shane P Community Member
      Hello All,
      I was wondering if someone has insight as to what could be causing a "r6025 - pure vital function call" error. I have been having this problem on
      and off for a while now. I see alot of others have had/are having this error and I have already searched through the forums and tried finding a
      solution before posting here.
      I have not seen any specifc references to the error in relation to my workflow when I receive it.
      Before moving forward, here are my system specs.
      Operating System:
          MS Windows Vista Home Premium 64-bit SP2 (Bag of shame over head :0)~ )
      CPU
          Intel Core 2 Quad Q6700  @ 2.66GHz    37 °C
          Kentsfield 65nm Technology
      RAM
          8.0GB Dual-Channel DDR2 @ 332MHz (5-5-5-15)
      Motherboard
          ASUSTeK Computer INC. P5QL PRO (LGA775)    31 °C
      Graphics
          HP w2408 (1920x1200@60Hz)
          512MB GeForce 9400 GT (MSI)    39 °C
      Hard Drives
          488GB Western Digital WDC WD5000AAKS-00H2B0 ATA Device (SATA)    33 °C
      Optical Drives
          WD Virtual CD 1110 USB Device
          ATAPI iHAS120   6 ATA Device
      Audio
          Realtek High Definition Audio
      Premiere Pro: CS4 4.2.1
      Ok, here's what happening:
      The only time I receive the above mentioned error is when I have a project open and I choose to import selceted sequences from another PP project
      file. If I choose to import a single sequence it pulls everything in fine, if however I choose multiple sequences I receive the error.
      The weird thing is that it is not a consistent error. For example, if I have a relativelty small project with just a handful of clips and
      sequences I notice that I am able to import multiple sequences from another PP project without issue. If I have a larger project with many
      sequences and assets, say maybe 50 sequences, 70-100 footage files, etc., and I proceed to import more than one sequence from another PP project I
      receive the error.
      I was originally thinking maybe PP is just choking as it is only accessing 4GB ram? Maybe the processor is not beefy enough? I don't think it is a
      software conflict as I only have some piriform products such a CCleaner, etc and Globalscape's CuteFTP installed. I use my system strictly for
      media creation like mostly everone here and do not and download the typical junk you see on most "home" systems.
      If there is a quick fix great, if not it's ok I will continue to deal with it but then my main question would be when I upgrade to 5.5 and Win 7
      Pro do you think this issue might be resolved ?
      Thank you in advance to anyone who may have any insight into this issue,
      Shane
        • 1. Re: r6025 error when inporting sequences.
          JSS1138 CommunityMVP
          My first guess was also a memory issue.
          If that is the source of this issue, then upgrading to 5.5 and working with 12GB, 16GB or more of RAM may well solve it.
          • 2. Re: r6025 error when inporting sequences.
            Jim,
            Thanks for the response. I downloaded the PP 5.5 trial and all I can say is WOW! The problem I was inquiring has been resolved. I can't believe the performance difference. As you can see by my specs above my pc is adequate but by no means stellar. Not only was I able to open the large project files and import multiple sequences, but I tried to get PP to choke and couldn't.
            The start up time difference on my system is amazing as well. As good as CS4 is/was, 5.5 makes it look stupid.
            I do have one question which I think I kno wthe answer to but just want to double check.
            When I downloaded the PP 5.5 trial I installed it that started opening up some CS4 project files. When it was converting them, some of the project files based on the filter I used received the following message:
            "Video Filter missing:  AE.SA ColorCorrect"
            I figured this was because I didn't install AE 5.5. I downloaded the trial and still the same thing. I am assuming because this is a filter not included with the trial of AE. When I purchase MC 5.5 next month and do a clean install (wiing drive and installing Win 7 Pro) would I be correct in assuming this should be resolved? If not is this an old filter that has been updatd by a newer one?
