I'm getting the error 'Marker id <num> not found' about 9 times out of 10 when I try to run unit tests in Flash Builder 4.5 Premium. This is happening on a new (2 weeks old) spark + mx project, with the unit test classes created in Flash Builder using the built-in tools. Using Run As or Debug does not seem to make a difference to whether the error occurs or not. I have to just keep retrying until it runs correctly.
I am using the AS Code Coverage plugin and the FlexUnit 4.1.
Please help as this is driving me mad!
Adam
I'm having this problem too. It's intermittent to start but when it happens it doesn't stop. I can't unit test!
Brent
Hi Adam, Brent,
Can you guys, post the screenshots with the your problems view and the project's reference libraries node in package explorer expanded? This would help me analyze the problem.
Sudhir
Here you go. Looks like it shrunk down the libraries image though.
I think it probably has something to do with breakpoints.
Can you try running again after removing all breakpoints. The ref library list looks clean.
