1. Re: PP cs5 wont import mts sound track
Harm Millaard Jul 4, 2011 7:32 AM (in response to cjacs987654)Both CS5 and CS5.5 will happily coexist on the same system. The only limitation of the trial version of CS5.5 is the time, there are no other limitations. Something must have messed up your installation. The other thing could be that your audio is using LPCM or some other weird format.
2. Re: PP cs5 wont import mts sound track
JSS1138 Jul 4, 2011 9:11 AM (in response to cjacs987654)Where exactly did you get these clips?
3. Re: PP cs5 wont import mts sound track
Bill Hunt Jul 4, 2011 9:12 AM (in response to cjacs987654)Chris,
Open one of the problem MTS files in MediaInfo, and look closely at the Audio Stream in it. What are the specs.?
Good luck,
Hunt
4. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 4, 2011 11:16 AM (in response to JSS1138)Hi Jim
From my Canon HG21 avchd camcorder. I forgot to mention, I had no problem with these files
before I installed cs5.5 trial - so if its not adobe, something must of upset the apple cart.
Thanks for your reply
Chris Anderson
5. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 4, 2011 11:18 AM (in response to Bill Hunt)Hi Bill
Great little utility - thanks for that
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 129
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -80msRegards
Chris
6. Re: PP cs5 wont import mts sound track
Colin Brougham Jul 4, 2011 11:35 AM (in response to cjacs987654)Chris,
These files should be totally workable in both CS5 (licensed version) and CS5.5 (trial and licensed). When you say that there is no audio, do you mean that the clips import as video-only, or do they import as video and audio, but you can't hear it on playback?
7. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 4, 2011 12:50 PM (in response to Colin Brougham)Hi Colin
When I import them, just video ie no audio settings show. When I drag to timeline only the video track is populated
I have even created a sequence by dragging the file over the new sequence icon to match settings etc
The file plays back on the camera no problems
Regards
Chris
8. Re: PP cs5 wont import mts sound track
Colin Brougham Jul 4, 2011 1:03 PM (in response to cjacs987654)That's really bizarre. I've really never known Premiere Pro--or any other Adobe product, for that matter--to mess with another application's ability to do this or that. I know you said this happened around the time or as a result of installing CS5.5, but was there anything else that you did/updated/installed in the interim?
9. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 4, 2011 2:06 PM (in response to Colin Brougham)Hi Colin
Thanks for your continued help
Not that i am aware.
Since last post I have imported another mts file that I recorded some time ago from the same camera, and that works fine!!!
Now im really confused.
Chris
10. Re: PP cs5 wont import mts sound track
Colin Brougham Jul 4, 2011 2:10 PM (in response to cjacs987654)OK, find the CFA/PEK files that are associated with the original clips, and trash them--do this with PPro closed. When you reopen the project, the files will be regenerated; all should be well then.
11. Re: PP cs5 wont import mts sound track
kevtra11 Jul 4, 2011 4:06 PM (in response to Colin Brougham)I'm having this exact same problem with same Canon AVCHD camera clips or any other file format. I have no audio track when I drag the clip to the timeline. I have the trial version of the master suite installed. Where do I find the CFA/PEK files?
Thanks for any help, Kevin
12. Re: PP cs5 wont import mts sound track
kevtra11 Jul 4, 2011 4:35 PM (in response to kevtra11)I have an update to this problem I would like to share.
I ran across this link that solves this. http://www.video2brain.com/en/videos-4009.htm
Turned out to be a simple solution.
Thanks, Kevin
13. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 5, 2011 1:57 AM (in response to kevtra11)Hi Kevin
what are cfa/pek files please?
Chris
14. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 5, 2011 1:58 AM (in response to kevtra11)Hi Kevin
Thanks for your reply, but this doesnt work for me, as the file when imported into the bin area does not show any audio properties.
I double checked by dragging to the timeline like the video link you sent, but it is not there
Regards
Chris
15. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 5, 2011 2:05 AM (in response to Colin Brougham)Hi Colin
What are CFA/PEK files and where are they stored. I cant find them on my PC anywhere. However, i have created a brand new project
and imported the mts file, and still no audio.
The MTS file came from my camcorder, should the cfa/pek files be associated with that?? because only the mts file is on my cameras
hard drive.
Regards
Chris
16. Re: PP cs5 wont import mts sound track
Harm Millaard Jul 5, 2011 2:18 AM (in response to cjacs987654)CFA is conformed audio and PEK are waveform peak files. Both are in your media cache as setup in your preferences.
17. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 5, 2011 3:55 AM (in response to Harm Millaard)Harm/Colin
Thanks for yoru replies.
I did this:
1. Exit prem pro app
2. Went to the disk cache folder - there was no cfa/pek file for the clip involved (there were for other files)
3. Deleted all cache files for this clip and all other clips
4. Started up Prem pro, new project - accepted defaults ie avchd 1920x1080 etc
5. Imported the clip involved
6. problem still exists - checked the cache folder - NO cpa/pek files exist
7. Imported mp4 file - audio showed ok no problem
8. Checked cache folder for this mp4 and cpa/pek files DO exist
So obvoiusly PP is not creating the cpa/tek files for the .mts file
I have now uninstalled the trial cs5.5 production premium, but it makes no difference. I havent yet re-installed cs5 master collection
I would welcome Todd or anyone else from Adobe looking at this please
Regards
Chris Anderson
18. Re: PP cs5 wont import mts sound track
Colin Brougham Jul 5, 2011 6:02 AM (in response to cjacs987654)Chris,
What sounds like is happening is that the media cache database has gotten clogged up; that's what tracks the media cache files that are generated for a particular piece of media. Let's try this:
Take the problematic MTS file(s) temporarily offline; you can do this simply by changing the name of the folder that the clips are in. (Optional, but I'd suggest this) In your OS file browser, search for all CFA and PEK files and delete them. On Windows 7, at least, you can type (without quotes) "cfa OR pek" into the Explorer search bar at the root of your drives, and you'll find all CFA and PEK files; you can select them all and trash them. If you're on a Mac, I'll assume you know how to search and delete there. Yes, this will force Premiere Pro to regenerate all CFA and PEK files for any project and media you open, but we need to purge the system here to try to get back to square one. This may not be absolutely necessary, but I'd really recommend doing it.
Create a fresh PPro project, and then go to Edit > Preferences > Media, and under the "Media Cache Database" section, click the "Clean" button. This may take a few moments or minutes, depending on how large the MCDB is. Once it is complete, close Premiere Pro. Put your "broken" media back online (e.g. change the name of your folder back to what it was), and then try a new project and import the previously broken media into it. How goes it at this point?
19. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 5, 2011 8:32 AM (in response to Colin Brougham)Hi Colin,
Really appreciate your help
I followed those steps 1 by 1, and the same problem exists. I then went on to remove all files in my cache directory - absolutely everything - created
a new project - import - no joy
Regards
Chris
20. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 6, 2011 7:05 AM (in response to cjacs987654)Update for everyone.
I recorded a new clip on the same camcorder, no change in settings ie 1920x1080 25p avchd
IMported this file and that one is ok, so it seems it is something to do with the specific clip.
However it plays fine in windows media and VLC media player
so im baffled.....
Chris
21. Re: PP cs5 wont import mts sound track
Colin Brougham Jul 6, 2011 7:21 AM (in response to cjacs987654)Chris,
Let's try one last brute force technique...
By default, your Media Cache Database should be in something like C:\Users\username\AppData\Roaming\Adobe\Common, but confirm this by going to Preferences > Media in PPro. Close Premiere Pro. In Explorer, navigate to that folder, and move all the .mcdb files that are there (there are probably a lot of them, but they're small) to another location on your drive--just cut and paste them.
Now, relaunch Premiere Pro and reopen the project with the troublesome media; at this point, everything is going to be reconformed/reindexed, and new Media Cache DB entries will be generated. Anything?
22. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 6, 2011 8:14 AM (in response to Colin Brougham)Hi Colin
Nope! - i made sure all cache files were gone, just an empty directory then relaunched pp.
When i add the 'good' file, the cfa/pek files are generated ok
Below is the info from mediainfo for the 'good' file and the 'bad' file. First the bad file:
Odd - note the 'duration' field, shows on good file but not bad file??
Chris
General
Complete name : V:\Source Material\Source Footage\Test Footage\Test audio xx\HG21.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 198 MiB
Overall bit rate : -23214266604056551000
Maximum Overall bit rate : 24.0 MbpsVideo
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=24
Codec ID : 27
Bit rate mode : Variable
Maximum bit rate : 22.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field FirstAudio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 256 Kbps
Bit depth : 16 bits
now the 'good file'General
Complete name : E:\00094.MTS
Format : BDAV
File size : 20.1 MiB
Duration : 7s 110ms
Overall bit rate : 23.5 Mbps
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 7s 120ms
Bit rate : 22.3 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.431
Stream size : 18.9 MiB (94%)Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 7s 200ms
Bit rate : 256 Kbps
Bit depth : 16 bits
Stream size : 225 KiB (1%) -
23. Re: PP cs5 wont import mts sound track
Colin Brougham Jul 6, 2011 8:27 AM (in response to cjacs987654)Heh. Check out the Overall Bit Rate field for the bad file...
That's a sure sign of a damaged file, and if this worked before, that means Premiere screwed it up. I've had it happen. What probably happened is that Premiere tried to write XMP data to this file and borked it; Premiere isn't supposed to (or at least in my experience, isn't able to) write XMP to an MTS file.
Sounds weird, but try opening the broken MTS file in a text editor; I like Notepad++ for such things. Head down to the end/bottom of the file; everything will be gibberish, but you might see some human-readable text/XML at the bottom. Let me know if you do.
24. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 6, 2011 9:02 AM (in response to Colin Brougham)Hi Colin,
No text.html, just usual 'jibberish'
If adobe has mucked it up, dont forget it still is ok in windows media player!!
Anyway, you have spent a lot of time on this, at least I know it is file specific so hopefully it wont happen again
Would be 'nice' to know from adobe if they do change the file at any time, i would of thought not.
Anyone ffrom adobe .......?
Chris
25. Re: PP cs5 wont import mts sound track
Colin Brougham Jul 6, 2011 7:37 PM (in response to cjacs987654)Hey Chris,
I took a look at the sample files you uploaded--pretty interesting. The faulty file appears to be missing large chunks of data, which is effectively breaking it. I was able to import it into Premiere Pro, with audio, but have a look at this:
We know the duration of the original file is correct--but the faulty one is not correct. I tried demuxing the faulty file and putting it back together again, but as you can see, the "fixed" file shows the exact same duration. This suggests that it wasn't just a problem with the container, but the streams themselves are damaged beyond repair. I'm not sure why I was able to get audio but you weren't, but it's sort of immaterial--the file wouldn't have been usable, anyway.Interestingly, the faulty file will playback in WMP and VLC--partially. Both will only play up to about the 31 second mark, and then stop. So, there's a lot broken here.
At this point, I don't think that it would be possible for Premiere Pro to do this kind of damage to the file. I've honestly never seen anything like it. It's almost like you have some bad sectors on your hard drive! That's the only explanation I can come up with at this point; if it was a bad file copy process or similar, the file would not have the exact same file size as the original file. It would sort of explain why the file was working, and then all of a sudden did not. There's just no way that I conceive the Premiere would have essentially erased a large portion of this file.
So, ultimately, I would chalk this up to a weird fluke, and suggest that you scan your hard drive! If nothing else, this underscores the importance of backing up your original media, just in case something happens...
Anyway, I hope that you have nothing but smooth sailing beyond this point! And backup early, backup often
26. Re: PP cs5 wont import mts sound track
cjacs987654 Jul 7, 2011 2:42 AM (in response to Colin Brougham)Colin
Many thanks for all your time on this - much appreciated. I wil take a look at my hard drive, but i do maintain it quite regular.
I also have a rigous backup system thankfully.
Still cant understand why it plays audio on your system but not mine, but as you say the file is damaged in places. When i said
in the forum earlier that the file played in windows media and vlc, I had not played it 100% - I assumed if it played at all the file
would be fine - something learnt there!
What is demuxing?
Promise i wont take any more of your time!
Regards
Chris
27. Re: PP cs5 wont import mts sound track
Colin Brougham Jul 7, 2011 7:02 AM (in response to cjacs987654)Chris,
The hard drive is just a possibility; I'm at a loss as to explain the damage that was done to the file. Obviously, keep an eye out for similar behavior. As mentioned, I don't think that Premiere Pro would be responsible for whatever happened to this file, but if you see it happen again, it's certainly something to report. For now, I think it's safe to consider this an isolated incident, but in case it is a hardware issue, you'll want to take precautions.
Not sure why the audio came through, but I suspect it has something to do with the Media Cache files and the Media Cache Database. Since my computer never had a "record" of this file, Premiere Pro knew to generate a fresh CFA file. Again, this is only a guess, but since the file was so damaged (and you fortunately had a backup, if you needed it), you're really not losing out on much.
Demuxing is shorthand for "demultiplexing." When you multiplex or "mux," you're creating a single playable media file from "raw" streams of audio, video, and data, and packaging them into a container file format that can be handled by various players or editors. When you demultiplex, you're essentially reversing the process: you're unpacking the "box" and putting the contents out on your desk. If the streams are good but the container was bad, you can put the streams back in a new container (often called "remuxing") and usually play the file back. In the case of this file, however, the streams themselves are damaged beyond repair, so remuxing wasn't working. That's the reason that the "fixed" file showed the exact same duration as the faulty file.
Ordinarily, this is not anything you'd have to do on a regular basis--it's sort of a last ditch effort to fix something broken. However, remuxing can be really useful when you have a file that is fine but won't play back on the host system; for example, I've been helping a few folks lately who have Apple HDV MOVs on a Windows machine (they won't play) by rewrapping them into new containers. The new files work fine then, without any re-encoding of the original video and audio streams! It's fun but extraordinarily geeky stuff
Don't be worried about asking questions--we're all here to help! Good luck!
Colin
28. Re: PP cs5 wont import mts sound track
Mr. MatuskeY Oct 29, 2011 2:08 PM (in response to cjacs987654)I'm using CS5.5 and have been reading forums and trying all of the various suggestions(re-linking the media; replacing the media; restarting; resaving; moving all files then edit undo) and just wanted to let everyone know that going into the cache files and deleting everything so that Premiere would have to re-generate the media WORKED! WOOOHOOO! Hope anyone else that has this problem resloves it. Consider it. Delte your cache. Someone suggested making sure that Premiere is closed before deleting, that's what I did. Wondering if this will work for my dynamic link to adobe after Effects too, the media keeps going offline after restarting the software. We'll see. Thanks for the help everyone.
BrYan
29. Re: PP cs5 wont import mts sound track
OnTwoWheels77 Oct 31, 2011 11:25 AM (in response to cjacs987654)PP CS5.5. I too suffered from mts files without sound after importing. Since the mts file plays perfectly outside of PP, then the problem is PP and its importing of files. I imported numerous mts files all at once and a few came through without sound. I simply renamed the "broken" original mts file by adding an underscore and number to the original file (xxxx_01). I imported the renamed file by itself and the import was successful. I then deleted any "broken" files I had previously imported. It looks to me like PP is having an issue with batch importation of files.... Hope this helps someone.
30. Re: PP cs5 wont import mts sound track
glosstud Oct 31, 2011 11:43 AM (in response to OnTwoWheels77)Hi, sorry but i have not read all the threads on this but this is what i do when importing mts files. I do not do it from PP instead I connect to vid cam on usb and drag n drop the files into a new folder usually on desktop. Then when they are ready I then drag and drop them into PP. This works for me but may be a backward way of doing things but at least I know I have taken a potentially problematic equation out of the loop by keeping things simple as the audio files remain linked to the video files.
Again sorry for maybe being a bit misunderstood as not had time to read other posts as have issues of my own, so my input may be useless but if it works then great.
Dave.
