1
HOW TO DETECT A MODIFIED PDF FILE
Jul 06, 2011 Jul 06, 2011
Hello everyone,
I re-post this message because I've found a way to detect that a file as been modified . I found that any modification may corrupted the cross reference table & it's easily detect with "bycepdfdata" , a software that shows metadata.... But I don't know if it do detect a file modified with acrobatpro ? Your opinion ?
Thank you
How to , Windows
192.6K
There is no sure proof way to determine if a generic pdf file is modified. If you go to the document properties (control or command d), if the proper metadata is available, it will list the creation date and time and modified date and time. This can help you determine if a pdf file has been modified since creation. However, it is not foolproof. This metadata is not secured. The easiest way to detect if a file has been modified to to digitally sign the document. Reader and Acrobat will report if the document has been changed since it was signed.
But in case of a non digitally signed doc , you can detect if the cross ref table as been corrupted by using the software amention above .
My question was : when you modify a pdf with adobe arc pro , does it corrupted the ref table ?
No.
Oct 23, 2019 Oct 23, 2019
I am using timestamps to track copy editors edit updates on PDF documents. As I understand from the forum my copyeditors are able to change the edit times. I would like to make it impossible for them to do so. The current process allows me to access first to the PDF document and then send it to them for copy editing work. Ideally, before sending it to them, I would block their ability to change edit times. Is that possible?
Thanks in advance-
Mar 30, 2024 Mar 30, 2024
Hey. Hope you can help.
If I sign it will the document update itself to say I have signed it?  For example: I have a print of a pdf supplied to me. On the last page it says :
Signed electronically by both parties
Hope you can help
Adobe Employee ,
Apr 09, 2024 Apr 09, 2024
Hi @Joseph364176090e93,
Hope you are doing well. Thanks for writing in!
If you have signed the file, it will be changed to a read-only version. Also, if you have the file signed using a digital certificate, you can check its authenticity. More info here: Validating digital signatures, Adobe Acrobat
Hope this helps.
-Souvik
Got your issue resolved? Please label the response as 'Correct Answer' to help your fellow community members find a solution to similar problems.
Mentor ,
As I understand it, if you modify (edit) a PDF with Acrobat Pro, it will create a new reference table on save that coincides with the changes made. At that point a new "created" date is applied.
If you don't want anyone to modify your PDFs, why not just lock and password protect them?
Dec 13, 2021 Dec 13, 2021
You can use a checksum by right click and then crc sha, its not a guarante, but if its the same its probably the same
