Locked
STUCK - Building Your First PHP-Based Mobile Application
Jul 06, 2011 Jul 06, 2011
Using FB 4.5.1 (Build 313231) Windows 7 64-bit OS.
IIS 7 and ZendServer already in place.
Very new in PHP, experienced in other development tools/languages.
This is the tutorial:http://files.zend.com/help/Flash-Builder-for-PHP/Getting-Started/Mobile/build_a_mobile_(php)_applica...
You can download the code and the DB from such link.
I can follow thru -> Step 11: Run a PHPUnit Test on Your PHP Service
There, I can't go on.
I hope the images are displayed well, just in case, the message is:
"Unable to run a PHPUnit session. Only PHPUnit classes can be run as PHPUnit tests.
Reason:
No test found in services/EmployeeServiceTest.php"
http://imgur.com/a/G5F5D
PHP
747
Just in case, the link takes you into the images. http://imgur.com/a/G5F5D
Thanks in advance for any help.
Best regards.
Cesar
Guest
Can you check that the PHPUnit library was added correctly? This message is usually presented when the class you are trying to run is either not PHPUnit compatible or since it cannot be resolved as a valid PHPUnit test case (since PHPUnit library is not installed correctly/at all).
Roy
