Hi there
you need to do the following to fix up the associations in Vista
1. go to control panel
2. default programs
3. set associations
find the ".pdf"
4. go to the "change program" button and chose Adobe
hope this helps
I was getting so frustrated and tried sooooo many different "fixes". Yours worked! Brett, you Rock!
WOW Brett thanks so much for the tip it worked a treat!!!!!! Thank you so much
[spam link removed]
Try repairing / reinstalling the latest version of Adobe 8 / 9 , if this doesn't solve your problem you need to edit the default adobe reader setting in the registry.
For information on the Windows Registry Editor, see the documentation for Windows or contact Microsoft Technical Support.
The default path for Reader is "C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe".
The default path for Acrobat is "C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrobat.exe".
for full details visit: http://kb2.adobe.com/cps/405/kb405461.html
I solved this by going to
Control Panel\All Control Panel Items\Devices and Printers
right click on the pdf printer program you want and select make default
BRETT, YOU RULE. THIS WORKEDFANTASTIC!
This 6½ year old topic is now locked.
(Ok, 5½ years.)
