I created a flow chart in Visio, and saved it as an html file. I imported that file into RH9, and got an error message when I tried to view it. This error displays even after I close Visio. I verfied that the file is not displaying in the browser.
When you click OK, you get this:
When you click Finish, the dialog closes. If you click New Topic, you create a new empty topic with that name as the topic title - the flowchart isn't in the topic. If you attempt to view the original flowchart, the sequence begins again. I have no idea what the second dialog is for, but so far it hasn't done anything useful.
I could save the flowchart as a PDF, but I was hoping to create hotspots on the chart to link to topics. Is this not do-able?
You need to create a JPG from Visio and then in RoboHelp you can create hotspots linking to topics.
The jpg worked perfectly. Thanks!
Hi there
To fix the initial issue, click Tools > Options > File Association and enable "Use Default Editor".
The fact that you are seeing the Frameset properties seems to suggest that Visio creates a frameset to present this stuff. Do you see other HTML pages?
Cheers... Rick
