5 Replies Latest reply on Jul 22, 2011 7:23 AM by Swat_mpg
    clear signature but do not unlock previously locked fields
    Swat_mpg Newcomer
      I have designed a form in LiveCycle ES 8.2.1 in which certain fields are locked when a check box is checked. They should remain locked. However, when a first digital signature is inserted and the user clears the signature. previously locked fields get unlocked. These fields must always stay locked.  Does anyone have a solution for this?
        • 1. Re: clear signature but do not unlock previously locked fields
          SForrest96 Champion
          Are you executing JavaScript to lock the fields when the check box is selected?  If so, can you re-run the script to have the fields lock again.  You could check the status of the signature field, if it is unsigned then you could fire the script to lock the fields associated with the check box.
          Regards
          Steve
          1 person found this helpful
          • 2. Re: clear signature but do not unlock previously locked fields
            Swat_mpg Newcomer
            I'll give it a try and will let you know.
            Thank you!
            mpg
            • 3. Re: clear signature but do not unlock previously locked fields
              Swat_mpg Newcomer
              I have added the code in Employee Signature field Change event to check the signature status and lock fields if the checkbox is checked . But it is not working.
              The requirement is that if the check box is checked, all the fields above that must be locked whether signature is valid or cleared.
              This is the first form I have designed in LiveCycle. So I would appreciate any help in this matter.
              swat_mpg
              1. This is the code
              form1.SubformMain.SubformText.SubformSignatures.EmployeeSignature::change - (JavaScript, client)
              var digSig = event.target.getField(GetFQSOMExp(this));
              var status = digSig.signatureValidate();
              app.alert(status);
              switch (status)
              case 0:
              case 1:
              case 2:
              if ( form1.SubformMain.SubformText.chkAppraisalComplete === 1)
              xfa.host.messageBox("Signature status is:- "
              & status)
              form1.SubformMain.SubformName.txtfLast.access
              = this.rawValue?"readOnly":"open";
              form1.SubformMain.SubformName.txtfFirst.access
              form1.SubformMain.SubformName.txtfInitial.access
              form1.SubformMain.SubformGeneral.txtfDivision.access
              form1.SubformMain.SubformGeneral.txtfPosition.access
              form1.SubformMain.SubformGeneral.txtfTimeInPosition.access
              form1.SubformMain.SubformGeneral.txtfTimeWithSupervisor.access
              form1.SubformMain.SubformGeneral.txtfSupervisor.access
              form1.SubformMain.SubformGeneral.DateFrom.access
              form1.SubformMain.SubformGeneral.DateTo.access
              txtfA.access
              txtfB.access
              txtfC.access
              txtfD.access
              txtfE.access
              form1.SubformMain.SubformText.chkAppraisalComplete.access
              break;
              2. Image of the Partial form
              • 4. Re: clear signature but do not unlock previously locked fields
                SForrest96 Champion
                swat_mpg
                I created a simple sample that, I think, achieves what you want to do.
                I created a form that will set the access on some fields to readOnly based on the value of a checkbox (selected = readOnly, un-selected = open)
                I then have a signatureField that "onChange" triggers the click event of a hidden button that contains code to set a flag in a field (not required in your case, but I built this sample off of one I created previously) and it sets the Check Box itself to "readOnly" so it cannot be accessed, preventing it's associated fields from being changed back to open, by de-selecting the check box.
                Please note that fields can be locked by a signature field by using a field collection (and no script), but the lock is disabled if the signature field is cleared.  For demo purposes, I created a field collection that contains the checkbox and I associated it with the signature field.
                Take a look at the attached sample.
                Steve
                • 5. Re: clear signature but do not unlock previously locked fields
                  Swat_mpg Newcomer
                  Thank you very much for your help.
                  I tried the code "var oSigState = event.target.getField("form1[0].#subform[0].SignatureField1[0]").signatureInfo().status;" .
                  However, it gave the following error:
                  event.target.getField("form1.SubformMain.SubformText.SubformSignatures.EmployeeSignature") .signatureInfo is not a function
                  3:XFA:form1[0]:SubformMain[0]:SubformText[0]:SubformSignatures[0]:Button[0]:click
                  So I substitued that line of code and some more code form another blog with
                  var
                  The form is working now just the way it is supposed to. Thanks to you!
                  swat_mpg
