Experienced DW designer learning CFMX7. I cannot seem to get
beyond this error message when using the Insert Record server
behavior to write data from a form into the database. Using MS
Access 2002, CFMX7's internal server, DW 6.0. Please note that I am
learning development for the first time and am using tutorials. I
was able to connect at one point but now I cannot.
See error message below:
The following information is meant for the website developer
for debugging purposes.
Error Occurred While Processing Request
Error Executing Database Query.
Syntax error in INSERT INTO statement.
Resources:
Enable Robust Exception Information to provide greater detail
about the source of errors. In the Administrator, click Debugging
& Logging > Debugging Settings, and select the Robust
Exception Information option.
Check the ColdFusion documentation to verify that you are
using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1;
SV1; .NET CLR 1.1.4322)
Remote Address 127.0.0.1
Referrer
http://localhost:8500/moosek/TMPu724j3nl2j.cfm
Date/Time 07-Aug-06 07:23 PM
Text
Text
