CP 5.0 question re: more than one active click box per slide
Guest
Jun 27, 2011 Jun 27, 2011
HAVEN'T HEARD BACK. RETESTED IN CAPTIVATE 5.0 (NOT 5.5), AND AM STILL HAVING THIS PROBLEM.
I BELIEVE THERE'S STILL A BUG WITH BRANCHING AND CLICK BOXES, UNLESS I'M DOING SOMETHING WRONG.
CAN I SEND SOMEONE A SAMPLE FILE SO THEY SEE WHAT I MEAN?
I'm using Captivate 3.0, and I'm creating a movie testing learner competence with various sections, one per task. For each task, learners need to click through everything correctly, or they branch back to a "Want to try again?" slide with Yes/No click buttons, both of which are active. The Yes button does a Continue, so learners can retry the task. The No button branches past all the tasks to the last slide, which consoles them and thanks them for their efforts. 🙂
I've got these click buttons set up to pause after 1.5 seconds but display for the rest of the slide. Thus both show up as Active for half the slide, then Inactive for the rest of the slide.
This works mostly, but when testing aggressively (for example, getting the same step wrong multiple times), it works the first time but only intermittently after that, often just proceeding on to the next slide instead of branching back to the "Want to try again?" slide. AND WHEN IT DOES BRANCH BACK TO THE YES/NO SLIDE, SOMETIMES THE YES BUTTON DOES NOTHING.
Am I doing something wrong?
Thanks very much for your help,
Rosie
Getting started
916
Guest
Jul 12, 2011 Jul 12, 2011
I changed one of the click boxes to Go to Next Slide instead of Continue, and that seemed to help. (The other slide branches to the last slide and has never been a problem.)
This works in CP 5.0 but not in CP 3.0.
Engaged ,
Jul 15, 2011 Jul 15, 2011
Not sure about 5.0 (or 3.0 or 5.5 for that matter!) but on Cp4 buttons appear to be one shot only.
I've had situations where a button has a pause and success action to continue. So if the learner clicks before the pause point the button correctly continues ... up to the pause point. Where it sits idle, having exhausted its only click opportunity.
If that's the issue then we discussed this in a whole lot more detail on another thread that I can't find at the moment thanks to the ropey search.
edit: Found it:
http://forums.adobe.com/thread/749043
Guest
Thanks - that might be the issue.
One thing I did try in CP 5 was to change the Continue button to a Go
to next slide. That fix worked in CP 5. Unfortunately it didn't work
in CP 3, and I'd rather use CP 3 because of the Action Script
incompatibility between CP 5+ and Articulate.
So...just a one-click opportunity? I'd love to see the more detailed
thread. Can anyone find it for me?
Rosie
Guest
Thanks for providing a link to the other discussion (which in turn linked to further discussions). I think that's indeed the issue.
I'm going to try shortening the Pause point to .5 or something like that (since I read that .1 might be a little too short).
Guest
Moving the Pause point to 0.5 seconds (together with choosing "Go to next slide" seems to help a lot. If someone sneaks in before 0.5 seconds, well, too bad! Thanks for your help with this. Would like to indicate that your answer was the correct one. Don't see that button currently.
Engaged ,
Jul 18, 2011 Jul 18, 2011
You're welcome Rosie
The thread shown as answered so that should be enough
Help resources
