A new blog on the topic “Create a Book Packager using Extendscript” has been posted at http://blogs.adobe.com/techcomm/2011/07/create-a-book-packager-using-extendscript.html
The blog demonstrates a script that creates a Book Packager that can be used to gather all the assets of a book or a document from differenet locations into a single target directory given by the user. The archive can be then be easily shared across as a self-contained book. The script is attached for your reference.
This describes how Extendscript can be used to create plug-ins and utilities that can ease repetitive workflows and do things with FrameMaker that you always wanted to do.
Anchal Arora
Adobe FrameMaker Team
The ZIP file containing the script will not open: "Cannot open file; it
appears not to be a valid archive." I opened the file in a text editor
and saw that it is actually a RAR file. When I changed the file
extension, it opened fine.
Mike,
I guess it depends upon the extraction tool used. It opened just fine for me using 7-zip. However, you are correct that it is using RAR compression.
Neither WinZip, Windows Explorer, or whatever unzip utility is built
into Directory Opus would open the file for me, until I changed the
extension. Then all three handle it without problem.
