I un- installed my previous version because I was having trouble loading farmville. I used the adobe uninstaller not remove programs. I can't reinstall the latest version in either Firefox or explorer. I have windows XP. I downloaded the Adobe support and it found nothing wrong. Help please.
It looks like the Firefox plugin is not installed. Try, once again, the MSI installer.
If you get any errors, please quote the exact messages you see.
You get this message during the download, or when you run the installer?
Try downloading the installers from http://www.adobe.com/products/flashplayer/fp_distribution3.html
I get failed to initialize during installation. That has been the site I have been using. Thank you for the reply. Any other ideas?
I went to this site also and downloaded both installers and I still get the failed to initialize error. I am using windows 7 32 bit.
Thanks Ido. I guess it must be an Adobe problem if I'm not alone. I hope someone fixes it.
HELP! Please!
What is the name of the installer you downloaded? What is the size of the installer?
The size should be
it is 713KB
install_flashplayer10_chrd_aih.exe
rikoshaprl wrote:
it is 713KB
Sorry, I have no idea what that is; where did you get that from?
Can you try to download the MSI installer(s)?
Sorry Geardownload.com
I went back to Geardownload.com and found a download for non explorer. I tried it on Farmville. It started but crashed. Now I am back to where the problem started.
The site given in reply number 1 is a 713kb size file too even though it is mssd
I don't understand any of this - I don't know what install_flashplayer10_chrd_aih.exe is; I don't know what Geardownload.com is; I don't know what mssd is...
I suggest that you do a clean uninstall (using http://kb2.adobe.com/cps/141/tn_14157.html), then download and run the two installers from http://www.adobe.com/products/flashplayer/fp_distribution3.html
Thank you for your help and patience Pat. I did what you recommended. The download link on the upper right hand corner of the site faile to initialize. The other links in the chart for windows all downloaded and installed, no problem. Firefox only recognized the EXE installer for plugins. But it still crashed when I tried to play farmville. I uninstalled, then downloaded each installer, them rebooted before trying to play. I appeciate your help!
So Flash Player is now installed for both Firefox and IE?
What files do you have in C:\Windows\system32\Macromed\Flash ?
Flash10u.ocx
Flash util10u_activex
Flash util10u_activex.dll
two text documents 101KB and 19KB
I see the Flash plugin in the system 32 file and Farmville loaded! Thanks much Pat, you did it!
I am having a similar issue; I just downloaded the latest version for Adobe 19.0.0.226 for mac and the file size is only 713 KB, with date created 10/15/15 and date modified 10/19/15. It downloaded perfectly fine but the file size isn't correct, and I'm wondering why it was modified at all.
