I am contiuing from an unresolved thread I done ages ago@
http://forums.adobe.com/thread/574764?decorator=print&displayFullThread=true
The point of interest is this:
Folks, I don't see anyone suggesting one feature that may help here. You don't really need to create files with these CFPDF* tags if you don't want to.
For instance, as seems Paule's issue, if one tag creates something that then another would use (as his CFPDFFORM result then being flattened), you can use the NAME attribute (instead of destination) to indicate a variable to hold the output of an earlier step, and then use that variable in the SOURCE of a later step.
It's a tag, not an attribute.
Im trying to do something like this:
<cfpdfform source="#source#" name="test2" action="populate" overwrite="yes" >
<cfpdfformparam name="1" value="1">
</cfpdfform>
<cfmail type="html" to="nikos@test.com"
from="wd" subject="hi"
mimeattach="#test2#"
however I get the error:
any ideas cf experts???
nb if I do a dump of test2 I get this:
PDFDocument | |||||||||||||||||||||||||||
Application | Adobe InDesign CS3 (5.0.4) | ||||||||||||||||||||||||||
Author | [empty string] | ||||||||||||||||||||||||||
CenterWindowOnScreen | no | ||||||||||||||||||||||||||
ChangingDocument | Allowed | ||||||||||||||||||||||||||
Commenting | Allowed | ||||||||||||||||||||||||||
ContentExtraction | Allowed | ||||||||||||||||||||||||||
CopyContent | Allowed | ||||||||||||||||||||||||||
Created | D:20110620135354+01'00' | ||||||||||||||||||||||||||
DocumentAssembly | Allowed | ||||||||||||||||||||||||||
Encryption | No Security | ||||||||||||||||||||||||||
FilePath | [empty string] | ||||||||||||||||||||||||||
FillingForm | Allowed | ||||||||||||||||||||||||||
FitToWindow | no | ||||||||||||||||||||||||||
HideMenubar | no | ||||||||||||||||||||||||||
HideToolbar | no | ||||||||||||||||||||||||||
HideWindowUI | no | ||||||||||||||||||||||||||
Keywords | [empty string] | ||||||||||||||||||||||||||
Language | [empty string] | ||||||||||||||||||||||||||
Modified | D:20110622160912+01'00' | ||||||||||||||||||||||||||
PageLayout | SinglePage | ||||||||||||||||||||||||||
PageRotations |
PageSizes |
What happens if you try cfmailparam instead of mimeattach?
I tried but get this:
It does not allow the attribute(s) CFMAILPARAM. The valid attribute(s) are BCC,CC,CHARSET,DEBUG,FAILTO,FROM,GROUP,GROUPCASESENSITIVE,KEYALIAS,KEYPASSWORD,KEYSTORE,KEYSTOREPASSWORD,MAILERID,MAXROWS,MIMEATTACH,PASSWORD,PORT,PRIORITY,QUERY,REMOVE,REPLYTO,SERVER,SIGN,SPOOLENABLE,STARTROW,SUBJECT,TIMEOUT,TO,TYPE,USERNAME,USESSL,USETLS,WRAPTEXT. T
thanks this produces the new pdf into a var:
but how do I flatten this?
I am not allowed to dot his:
<cfpdf action="write" flatten="yes" source="#test2#"
name="test2" overwrite="yes"> </cfpdf>
"not allowed to"? Why not?
Adam
get this error:
How does the "source" variable get its value?
Adam
<cfset source = GetDirectoryFromPath(
GetCurrentTemplatePath()
) & "pdf/cont_Editable.pdf">
And what does this output:
<cfoutput>
GetCurrentTemplatePath(): [#GetCurrentTemplatePath()#]<br />
source: [#source#]<br />
fileExists(source): [#fileExists(source)#]<br />
</cfoutput>
Adam
