0 Replies Latest reply on Jul 17, 2011 5:57 PM by Todd_Kopriva
    FAQ: Why do I have a red or yellow bar over my sequence, and how do I render previews?
    Todd_Kopriva Level 8
      The first thing to know is that a yellow bar isn't a sign of a problem (nor is a red bar, necessarily).
      See this article for details:
      Red, yellow, and green render bars and what they mean
      ... and this movie for a somewhat less detailed explanation:
      Why is there a red or yellow bar in my sequence?
      Here's the summary:
      • green: This segment of the sequence has a rendered  preview file associated with it. Playback will play using the rendered  preview file. Playback at full quality is certain to be in real time.
      • yellow: This segment of the sequence does not have a  rendered preview file associated with it. Playback will play by  rendering each frame just before the CTI reaches it. Playback at full  quality will probably be in real time (but it might not be).
      • red: This segment of the sequence does not have a  rendered preview file associated with it. Playback will play by  rendering each frame just before the CTI reaches it. Playback at full  quality will probably not be in real time (but it might be).
      • none: This segment of the sequence does not have a  rendered preview file associated with it, but the codec of the source  media is simple enough that it can essentially be treated as its own  preview file. Playback will play directly from the original source media  file. Playback at full quality is certain to be in real time. This only  occurs for a few codecs (including DV and DVCPRO).
      Note the uses of the word probably above. The colors aren’t a  promise. They’re a guess based on some rather simple criteria. If you  have a fast computer, then a lot of things marked with red may play back  in real time; if you have a slow computer, then some things marked with  yellow may need to be rendered to preview files before the segment can  be played in real time.
