15 Replies Latest reply on Dec 6, 2012 11:11 AM by dbec.
    Flash Media Server for Red Hat EL 6
    chrisdornan Level 1
      I have tried installinf FMS 4.0.2 on RHEL/CentOS 6 with no luck.
      The installer complains about missing libcap. When I supress the check the installer warns about installation on an unsupported O/S.
      Unfortunately, I can't it to work on CentOS 5. The log says:
      2011-07-17      00:39:40        23795   (i)2571011      Server starting...      -
      2011-07-17      00:39:40        23795   (i)2581224      Edge (23818) started, arguments : -edgeports ":1935" -coreports "localhost:19350" -conf "/opt/adobe/fms/conf/Server.xml" -adaptor "_defaultRoot_" -name "_defaultRoot__edge1" -edgename "edge1".        -
      2011-07-17      00:39:40        23795   (i)2571111      Server started (/opt/adobe/fms/conf/Server.xml).        -
      2011-07-17      00:39:45        23795   (i)2581226      Edge (23818) is no longer active.       -
      2011-07-17      00:39:45        23795   (w)2581255      Edge (23818) _defaultRoot__edge1 experienced 1 failure[s]!      -
      Followed by many more edge failures.
      Meanwhile the CentOS 5 installation works fine.
      Does anyone have any idea what the problem could be or whether there is a workaround?
        • 1. Re: Flash Media Server for Red Hat EL 6
          Adrian_NA
          Datasheet does not state support for EL6, only 5.3. I am sure one of the support guys may be able to help further.
          • 2. Re: Flash Media Server for Red Hat EL 6
            chrisdornan Level 1
            Thanks! -- this is the right place to ask isn't it, or is there somewhere else I should be asking?
            • 3. Re: Flash Media Server for Red Hat EL 6
              Adrian_NA Level 1
              You are in the correct forum section to ask. I do not have time to test on EL6 today
              • 4. Re: Flash Media Server for Red Hat EL 6
                dedy dumas
                I'am currently try the same things. I run FMS 4 in RHEL 6.
                after couple time installing the right package (libcap a.k.a. library package) I'am success installing FMS 4 with some comment:
                WARNING: Your Linux distribution, RedHat x86_64  is not supported by this
                          installer.
                but I keep on going with readme instruction:
                13) To start the server manually, go to the installation directory (default is /opt/adobe/fms/). Use the command "./fmsmgr server fms start" to start Flash Media Server and "./fmsmgr adminserver start" to start Flash Media Administration Server.
                [root@localhost ~]# cd /opt/adobe/fms/
                [root@localhost fms]# ./fmsmgr server fms start
                Server:fms command:start
                ./server: command substitution: line 46: syntax error near unexpected token `elif'
                ./server: command substitution: line 46: ` elif [ -f /etc/mandrake-release ] ; then'
                sed: -e expression #1, char 6: unknown option to `s'
                sed: -e expression #1, char 9: unknown option to `s'
                sed: -e expression #1, char 14: unknown option to `s'
                ./server: line 41: /etc/SUSE-release: No such file or director
                          installer.
                1024
                WARNING: FMS requires the maximum number of processes > 32K.
                         Adjust ulimit to match system requirements.
                NPTL 2.12
                Starting Adobe Flash Media Server (please check /var/log/messages)
                [root@localhost fms]# ./fmsmgr adminserver start
                Admin server:fmsadmin command:start
                ./adminserver: command substitution: line 45: syntax error near unexpected token `elif'
                ./adminserver: command substitution: line 45: ` elif [ -f /etc/mandrake-release ] ; then'
                ./adminserver: line 40: /etc/SUSE-release: No such file or directory
                          installer.
                Starting Adobe Flash Media Admin Server (please check /var/log/messages)
                I check in system monitor
                process name: fms admin and fmsmaster ; both status: sleeping.
                Q: 1. Does this mean FMS is running?
                Q: 2. is there FMS server adminstration console as in microsoft installation?
                The problems are: I can't connect adobe flash media live encoder 3.2, live application to the FMS
                FYI: I already try in Microsoft 2003 server R2. no problem at all, I can wacth live streaming fine in flv application.
                • 5. Re: Flash Media Server for Red Hat EL 6
                  chrisdornan Level 1
                  Thanks Adrian -- the acknowledgement is appreciated!
                  (The report from dedy dumas is constent with what I saw.)
                  • 6. Re: Flash Media Server for Red Hat EL 6
                    chrisdornan Level 1
                    RHEL 5 and CentOS 5 are now heading for their end of life (starting in 2011Q4); the RHEL 6 beta was made available in April 2010; as reported here, by more than one person, FMS does not work with RHEL 6.
                    Is Adobe planning to make a release of FMS that works with RHEL/CentOS 6?
                    • 7. Re: Flash Media Server for Red Hat EL 6
                      r.cira
                      I am running FMS 4.0 on RHEL 6.0 64bit.  It took some work but everything is working properly.  I knew I should have writtien down what I did at the time, but I will try to recall and pass along what I did.
                      edit the installFMS script
                      search for
                      cd_check "Red Hat Enterprise Linux Client release 5" /etc/redhat-release redhat-RHEL5-i686
                      add the following line right below it
                      cd_check "Red Hat Enterprise Linux Client release 6" /etc/redhat-release redhat-RHEL6-i686
                      execute the installFMS script.  You can let the installer start the service, but they will fail.
                      Depending on your version of libcap, you will have to modify the libcap link in the /rootinstall/ (/opt/adobe/fms)
                      I had to delete the link and replace it with a symbolic link libcap.so.1 -> /lib64/libcap.so.2
                      If memory serves me there is one more file you have to modify, in the /rootinstall/ edit the server file
                      again search for
                      and add
                      Hope that helps.
                      1 person found this helpful
                      • 8. Re: Flash Media Server for Red Hat EL 6
                        calmchessplayer Level 3
                        dully noted thanks for reporting the answer. People like when i mark stuff as correct so that it attributes so to speak  into adobe database special probably helps other people find answers so could u mark yourself as giving the correct answer please.
                        • 9. Re: Flash Media Server for Red Hat EL 6
                          chrisdornan Level 1
                          Thanks r.circa! Your answer is encouraging. When I get a chance I will try to replicate the process. If I can I will take notes and post them here.
                          • 10. Re: Flash Media Server for Red Hat EL 6
                            Nikhil Pavan Kalyan Level 4
                            Hi everyone,
                            As of now , i do not know of any movement to RHEL 6, but if RHEL is itself moving to that distro , I guess we too follow them. I will update as soon as there is some information to share. Thanks for bringing this up.
                            For now, we do not have support for RHEL 6, good to know of the above workaround
                            • 11. Re: Flash Media Server for Red Hat EL 6
                              jabroome
                              According to  https://access.redhat.com/support/policy/updates/errata/    RHEL5 / CentOS 5 are supported until March 31, 2014https://access.redhat.com/support/policy/updates/errata/ .
                              Not sure where you got the EoL in Q4 2011.
                              • 12. Re: Flash Media Server for Red Hat EL 6
                                chrisdornan Level 1
                                2014 is for the end of production phase 3 or  the end of regular lifecycle.
                                However in 2011Q4 RHEL5 exits production phase 1 -- as I said 'heading for their end of life (starting in 2011Q4)' not that it had reached its end of life.
                                My point is that it would be much more desirable to go into production on RHEL6, not with an O/S that is heading for the exits, and so avoid having to make an expensive transition in a relatively short time frame.
                                The only component that has been holding this up is also the only component in the stack that is not open source; Adobe's disposition is duly noted.
                                I am glad there appears to be a workaround.
                                • 13. Re: Flash Media Server for Red Hat EL 6
                                  jbethke_SSI
                                  I just successfully used r.circa's solution to install FMS 4.5 on RHEL6 x64. All is working well. Thanks.
                                  • 14. Re: Flash Media Server for Red Hat EL 6
                                    Zone.Media.Coporation
                                    I config same, but show :
                                              installer.
                                    I's sever Centos 6 x86_x64
                                    Pls help
                                    • 15. Re: Flash Media Server for Red Hat EL 6
                                      dbec.
                                      Thanks again to "r.circa" who came up with the original solution. Here are some updated instructions that don't require creating a symbolic link to fix the libcap issue.
                                      I was able to get 4.5.4 working on RHEL 6.3. Here's what to do:
                                      Update to latest errata with 'yum update'; reboot
                                      Also make sure you have latest version of both libcap and compat-libcap1 packages (via yum update...)
                                      Exract the latest FMS install archive (4.5.4 as of this writing).
                                      In that folder, for a successful, error-free install you need to edit three files:
                                      server
                                      adminserver
                                      installFMS
                                      For 'server' and 'adminserver', edit these sections as follows:
                                        # Red Hat Linux
                                        if [ -f /etc/redhat-release ]; then
                                              cd_check "Red Hat Enterprise Linux [WAE]S release 3" /etc/redhat-release redhat-RHEL3-i686
                                              cd_check "Red Hat Enterprise Linux [WAE]S release 4" /etc/redhat-release redhat-RHEL4-i686
                                              cd_check "Red Hat Enterprise Linux Server release 5" /etc/redhat-release redhat-RHEL5-i686
                                              cd_check "CentOS release 4" /etc/redhat-release centos-4-i686
                                              cd_check "CentOS release 5" /etc/redhat-release centos-5-i686
                                              DIST='RedHat'
                                              PSUEDONAME=`cat /etc/redhat-release | sed s/.*\(// | sed s/\)//`
                                              REV=`cat /etc/redhat-release | sed s/.*release\ // | sed s/\ .*//`
                                          DIST="${DIST} ${REV} ${PSUEDONAME}"
                                              cd_result $DIST
                                      ..and:
                                      # check distribution
                                      PLATFORM="Linux"
                                      ARCH=`uname -m`
                                      SUPPORT=0
                                      DISTRO=`check_distro`
                                      case $DISTRO in
                                          redhat-RHEL5-i686)
                                          redhat-RHEL6-i686)
                                          centos-5-i686)
                                          Debian)
                                      Similarly, for installFMS edit these sections as follows:
                                        # Red Hat Linux
                                        cd_check "Red Hat Enterprise Linux Server release 6" /etc/redhat-release redhat-RHEL6-i686
                                        DIST='RedHat'
                                        cd_result $DIST
                                      and...
                                      PLATFORM="Linux"
                                      case $DISTRO in
                                          redhat-RHEL5-i686)
                                          redhat-RHEL6-i686)
                                          centos-5-i686)
                                              Debian)
                                      run installFMS as normal and it should just work.
                                      I hope that helps. I also hope Adobe starts to support RHEL 6 users. Seriously, how much effort would it take?
                                      Best,
                                      Daniel
