I have tried installinf FMS 4.0.2 on RHEL/CentOS 6 with no luck.
The installer complains about missing libcap. When I supress the check the installer warns about installation on an unsupported O/S.
Unfortunately, I can't it to work on CentOS 5. The log says:
2011-07-17 00:39:40 23795 (i)2571011 Server starting... -
2011-07-17 00:39:40 23795 (i)2581224 Edge (23818) started, arguments : -edgeports ":1935" -coreports "localhost:19350" -conf "/opt/adobe/fms/conf/Server.xml" -adaptor "_defaultRoot_" -name "_defaultRoot__edge1" -edgename "edge1". -
2011-07-17 00:39:40 23795 (i)2571111 Server started (/opt/adobe/fms/conf/Server.xml). -
2011-07-17 00:39:45 23795 (i)2581226 Edge (23818) is no longer active. -
2011-07-17 00:39:45 23795 (w)2581255 Edge (23818) _defaultRoot__edge1 experienced 1 failure! -
Followed by many more edge failures.
Meanwhile the CentOS 5 installation works fine.
Does anyone have any idea what the problem could be or whether there is a workaround?
Datasheet does not state support for EL6, only 5.3. I am sure one of the support guys may be able to help further.
Thanks! -- this is the right place to ask isn't it, or is there somewhere else I should be asking?
You are in the correct forum section to ask. I do not have time to test on EL6 today
Thanks Adrian -- the acknowledgement is appreciated!
(The report from dedy dumas is constent with what I saw.)
RHEL 5 and CentOS 5 are now heading for their end of life (starting in 2011Q4); the RHEL 6 beta was made available in April 2010; as reported here, by more than one person, FMS does not work with RHEL 6.
Is Adobe planning to make a release of FMS that works with RHEL/CentOS 6?
According to https://access.redhat.com/support/policy/updates/errata/ RHEL5 / CentOS 5 are supported until March 31, 2014https://access.redhat.com/support/policy/updates/errata/ .
Not sure where you got the EoL in Q4 2011.
2014 is for the end of production phase 3 or the end of regular lifecycle.
However in 2011Q4 RHEL5 exits production phase 1 -- as I said 'heading for their end of life (starting in 2011Q4)' not that it had reached its end of life.
My point is that it would be much more desirable to go into production on RHEL6, not with an O/S that is heading for the exits, and so avoid having to make an expensive transition in a relatively short time frame.
The only component that has been holding this up is also the only component in the stack that is not open source; Adobe's disposition is duly noted.
I am glad there appears to be a workaround.
I'am currently try the same things. I run FMS 4 in RHEL 6.
after couple time installing the right package (libcap a.k.a. library package) I'am success installing FMS 4 with some comment:
WARNING: Your Linux distribution, RedHat x86_64 is not supported by this
installer.
but I keep on going with readme instruction:
13) To start the server manually, go to the installation directory (default is /opt/adobe/fms/). Use the command "./fmsmgr server fms start" to start Flash Media Server and "./fmsmgr adminserver start" to start Flash Media Administration Server.
[root@localhost ~]# cd /opt/adobe/fms/
[root@localhost fms]# ./fmsmgr server fms start
Server:fms command:start
./server: command substitution: line 46: syntax error near unexpected token `elif'
./server: command substitution: line 46: ` elif [ -f /etc/mandrake-release ] ; then'
sed: -e expression #1, char 6: unknown option to `s'
sed: -e expression #1, char 9: unknown option to `s'
sed: -e expression #1, char 14: unknown option to `s'
./server: line 41: /etc/SUSE-release: No such file or director
installer.
1024
WARNING: FMS requires the maximum number of processes > 32K.
Adjust ulimit to match system requirements.
NPTL 2.12
Starting Adobe Flash Media Server (please check /var/log/messages)
[root@localhost fms]# ./fmsmgr adminserver start
Admin server:fmsadmin command:start
./adminserver: command substitution: line 45: syntax error near unexpected token `elif'
./adminserver: command substitution: line 45: ` elif [ -f /etc/mandrake-release ] ; then'
./adminserver: line 40: /etc/SUSE-release: No such file or directory
installer.
Starting Adobe Flash Media Admin Server (please check /var/log/messages)
I check in system monitor
process name: fms admin and fmsmaster ; both status: sleeping.
Q: 1. Does this mean FMS is running?
Q: 2. is there FMS server adminstration console as in microsoft installation?
The problems are: I can't connect adobe flash media live encoder 3.2, live application to the FMS
FYI: I already try in Microsoft 2003 server R2. no problem at all, I can wacth live streaming fine in flv application.
I am running FMS 4.0 on RHEL 6.0 64bit. It took some work but everything is working properly. I knew I should have writtien down what I did at the time, but I will try to recall and pass along what I did.
edit the installFMS script
search for
cd_check "Red Hat Enterprise Linux Client release 5" /etc/redhat-release redhat-RHEL5-i686
add the following line right below it
cd_check "Red Hat Enterprise Linux Client release 6" /etc/redhat-release redhat-RHEL6-i686
execute the installFMS script. You can let the installer start the service, but they will fail.
Depending on your version of libcap, you will have to modify the libcap link in the /rootinstall/ (/opt/adobe/fms)
I had to delete the link and replace it with a symbolic link libcap.so.1 -> /lib64/libcap.so.2
If memory serves me there is one more file you have to modify, in the /rootinstall/ edit the server file
again search for
and add
Hope that helps.
dully noted thanks for reporting the answer. People like when i mark stuff as correct so that it attributes so to speak into adobe database special probably helps other people find answers so could u mark yourself as giving the correct answer please.
Thanks r.circa! Your answer is encouraging. When I get a chance I will try to replicate the process. If I can I will take notes and post them here.
Hi everyone,
As of now , i do not know of any movement to RHEL 6, but if RHEL is itself moving to that distro , I guess we too follow them. I will update as soon as there is some information to share. Thanks for bringing this up.
For now, we do not have support for RHEL 6, good to know of the above workaround
I just successfully used r.circa's solution to install FMS 4.5 on RHEL6 x64. All is working well. Thanks.
I config same, but show :
installer.
I's sever Centos 6 x86_x64
Pls help
Thanks again to "r.circa" who came up with the original solution. Here are some updated instructions that don't require creating a symbolic link to fix the libcap issue.
I was able to get 4.5.4 working on RHEL 6.3. Here's what to do:
Update to latest errata with 'yum update'; reboot
Also make sure you have latest version of both libcap and compat-libcap1 packages (via yum update...)
Exract the latest FMS install archive (4.5.4 as of this writing).
In that folder, for a successful, error-free install you need to edit three files:
server
adminserver
installFMS
For 'server' and 'adminserver', edit these sections as follows:
# Red Hat Linux
if [ -f /etc/redhat-release ]; then
cd_check "Red Hat Enterprise Linux [WAE]S release 3" /etc/redhat-release redhat-RHEL3-i686
cd_check "Red Hat Enterprise Linux [WAE]S release 4" /etc/redhat-release redhat-RHEL4-i686
cd_check "Red Hat Enterprise Linux Server release 5" /etc/redhat-release redhat-RHEL5-i686
cd_check "CentOS release 4" /etc/redhat-release centos-4-i686
cd_check "CentOS release 5" /etc/redhat-release centos-5-i686
DIST='RedHat'
PSUEDONAME=`cat /etc/redhat-release | sed s/.*\(// | sed s/\)//`
REV=`cat /etc/redhat-release | sed s/.*release\ // | sed s/\ .*//`
DIST="${DIST} ${REV} ${PSUEDONAME}"
cd_result $DIST
..and:
# check distribution
PLATFORM="Linux"
ARCH=`uname -m`
SUPPORT=0
DISTRO=`check_distro`
case $DISTRO in
redhat-RHEL5-i686)
redhat-RHEL6-i686)
centos-5-i686)
Debian)
Similarly, for installFMS edit these sections as follows:
# Red Hat Linux
cd_check "Red Hat Enterprise Linux Server release 6" /etc/redhat-release redhat-RHEL6-i686
DIST='RedHat'
cd_result $DIST
and...
PLATFORM="Linux"
case $DISTRO in
redhat-RHEL5-i686)
redhat-RHEL6-i686)
centos-5-i686)
Debian)
run installFMS as normal and it should just work.
I hope that helps. I also hope Adobe starts to support RHEL 6 users. Seriously, how much effort would it take?
Best,
Daniel
