1. Re: Jerky Exported video
John T Smith Jul 18, 2011 12:48 PM (in response to flbreen)>raw video looks fine
Well... what IS that raw video?
Does your project 100% match that raw video?
What ARE your export settings?
2. Re: Jerky Exported video
flbreen Jul 18, 2011 1:15 PM (in response to John T Smith)I just found out that I had mistakenly converted some of the video I was using was to 24 fps.
Thanks for the consideration
3. Re: Jerky Exported video
flbreen Jul 18, 2011 1:18 PM (in response to flbreen)I mistakenly set the Sequence to 24 fps.
4. Re: Jerky Exported video
flbreen Jul 18, 2011 2:24 PM (in response to John T Smith)I use wide screen standard definition.
I have a Canon XF-A1a.
I load tapes in using Windows Live Movie Maker and I get the default .avi files on my PC.
I also use my FS-H200 recorder with my A1 in the mode that produces Type 2 avi files.
I mistakenly created a DV-24 Sequence and put the video segments from my recorder on the time line.
I made a single 1 hour long file to use instead of the short segments.
I used the same DV-24 segement to edit my video.
The tape files on timeline looked a lot better than the concatenated file made by that same DV-24 segement.
I started all over again using the usual DV-NTSC sequence
