In searching the forum, I found info about LInkit (thanks,
Rick), and downloaded it. Nifty! I fired it up, brought up our
application, and then pulled the little icon over and began
collecting application window names.
And here's the problem, for which the Linkit Help doesn't
provide a good answer. Like most apps I'm sure, the different
application tabs use the same "window" (speaking from a development
point of view), with differentiating names. In this case, here is a
sample of two similar window names:
http://.../Portal/main.asp?ptab=W_SCHEDULE&scode=6919
http://.../Portal/main.asp?ptab=W_ANLSYS&scode=6919
Because it's the same window, Linkit puts a red line around
the second window and won't collect it. Help says to right-click on
the collected window name and then click rename. I do so, however,
there is no shortcut menu at all, and no Edit-Rename function.
Has anyone done this?
Thank you,
Linda
