I tried to record Word 2010 with Captivate 5 with option "convert tooltips to rollover captions" enabled but no tooltip captions were generated. It generates text captions that says "click this and that" but it doesn't generate rollover caption. The same feature doesn't work in any MS Office 2010 app but it works fine in when I'm recording some other application. Any ideas how to solve this?
Hello,
I'm on CP5.5 now, but perhaps 2 tips: did you install the latest patch, release should be: 5.0.2.630
Is this the 32-bit or the 64-bit version of Word? I got back to 32-bit because I had too much issues with the other version.
Lilybiri
PS As a workaround, did you try to insert manually intermediate captured slides with PrintScreen?
I'm on version 5.5 actually, 32bit. Tried to update but there's no new updates available.
Yes, I know I can insert slides with screenhshot of tooltips but what I really need is to convert a tooltip text into text string (caption or whatever).
Sorry about the version, but because you were referring to CP5, and really use the latest release 5.5 I was confused.
I played a little bit capturing different apps in demo mode with this feature turned on (never used it myself because I'm almost never creating demonstrations, only trainings as assessments). And you are right: it is not functional in Office (used Excel and Word) 2010, but neither in TweetDeck (AIR application) nor Evernote. It is functional in Bridge and Photoshop. There a rollover area is created and the text from the tooltip is converted to a Text Caption, which is editable of course. But you should have to tweak both the rollover area and the caption a lot to have it looking like the original tooltip, hmmm.
Will certainly file a bug about this and it would be fine if you did likewise, but am wondering if all is not linked to the fact that most tooltips are really images (look at the Office-tips: there is a line and a help icon)...
If I wanted to have those tooltips looking like in the real application I would not use this conversion possibility but:
Seems a lot of work, but the result will be a lot more realistic.
Just one question: why do you want the tooltip text to be editable?
Lilybiri
I don't need tooltips to look like in original app. I only need to convert them to text strings.
Do not see how, sorry, just logged the bug.
Lilybiri
...just to answer why do I want the tooltip text to be editable... Because I want to copy paste it to another tool and I don't know another way to extract text from MS Office applications tooltips.
