Hi all,
I just started learning Flash Builder not too long ago, quite a learning experience I have to say. I am a little lost and woul like some help from you guys.
I am trying to build a menu tree that will display and image and information about that image when the corresponding node is selected.
I also want to have the menu tree searchable, I looked at a few examples of tree controls to get some ideas but I keep hitting brickwalls left and right.
I started over few times trying to follow some of the examples. Right now, I only have the visual elements, please see the code below.
Thank you so much in advance.
Here's the code I have so far:
<?xml version="1.0" encoding="utf-8"?> <mx:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="960" minHeight="560" backgroundColor="#FFFFFF" width="960" height="560"> <fx:Declarations> </fx:Declarations> <mx:HDividedBox y="80" height="415" x="25"> <s:Panel x="20" y="95" width="240" height="415"> <s:TextInput x="10" y="-25" height="20" contentBackgroundAlpha="1.0" borderAlpha="1.0" textAlign="left" fontWeight="normal" text="Search" focusColor="#70B2EE" fontSize="10" color="#646464"/> <mx:Tree id="tree" x="10" y="5" width="220" height="370" borderVisible="false" color="#787878"> </mx:Tree> <s:Button x="160" y="-25" label="Find" fontWeight="bold" fontSize="10"/> </s:Panel> <s:Panel x="275" y="95" width="660" height="415"> <mx:SWFLoader id="swfLoader" scaleContent="true" x="0" y="0" width="660" height="190"/> <mx:Text width="639" id="treeSelectedData" height="169" x="9" y="203"/> </s:Panel> </mx:HDividedBox> </mx:Application>
Any takers? C'mon!
Please let me know if I need to provide more information.
You should take a look at the help documentation about the tree component. They have an example code at the bottom that shows how to load in data to the tree and how to perform actions when a node in the tree is selected. Below is a link to the help documentation on the tree component.
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/mx/controls/Tree.html?filter_flex=4.5.1&filter_flashplayer=10.3&filter_air=2.6
Thank you for the link, I can't find how to search a tree though. Can you or anyone else shed some light on that?
Thank you.
Here is an article that talks about searching through XML data.
