Show 3 replies
1. Re: Advice On Upgrade
Dov Isaacs Jul 19, 2011 1:26 PM (in response to wayne greensill)You don't need to install the CS4 software on the new system, but you will need to be able to enter your CS4 serial number when you run the installer for the upgrade version of CS5.5!
- Dov
2. Re: Advice On Upgrade
wayne greensill Jul 19, 2011 1:47 PM (in response to Dov Isaacs)Hi there,
Thanks you for your fast response. So this applies to the upgrade version as well as the full version?
Wayne
3. Re: Advice On Upgrade
John Waller Jul 22, 2011 9:26 PM (in response to wayne greensill)So this applies to the upgrade version as well as the full version?
Yes. Upgrade disks and full version disks contain the same code.The only difference between them is the serial number required to convince the installer to install the software.
Insert the upgrade disk for CS5.5 on your new Win 7 PC.
The installer asks for a qualifying serial no.
Enter the CS4 serial no.
The installer will continue to install CS5.5.
