2 Replies Latest reply: Jul 25, 2011 10:25 AM by Webshark2000 RSS
    A couple of questions about burning Blu-rays in Encore
    Webshark2000 Community Member
      I've burned a few Blu-rays in Encore, but this is the first project that I have a large amount of footage and some large motion menus.  I've been having a few strange issues and maybe someone can answer some questions for me.  I'm using CS5.5.
      1.  Is there a way to export H.264 Blu-ray files from Premiere and have them retain the chapter markers when imported into Encore, like MPEG2 files do?
      2.  Why does Encore have to retranscode all of my motion menus every time I build the project, even if I haven't made any changes to the menus?  Because my motion menus are quite numerous, this process takes over an hour each time.  Doesn't Encore normally keep transcoded files so you can reburn the project quickly if you come back to it?
      3.  When I tell Encore to automatically transcode my video files using H.264, it shows the final Disc info as 25GB used and 7.005MB free, with 0 bytes used for BD-ROM content.  But if I try to build the project straight to a disc it transcodes everything (taking several hours) then fails saying the project exceeds disc capacity.  If I build it to an image, the image ends up being like 27GB and fails because of size if I try to burn it using ImgBurner.  What should I do?
      Thanks.
        • 1. Re: A couple of questions about burning Blu-rays in Encore
          MobyTrix Community Member
          Thanks.
          These two issues are bugs that I reported for CS5 and to my knowledge are still not fixed in CS5.5.
          For #2, there is no workaround so you should build the time into your workflow (ie. work on something else while it's building).  I found that even properly transcoded assets are STILL re-transcoded, so for those assets, I feed Encore the original master files to avoid two generational losses.
          For #3, the Image build sometimes pads too much and creates an invalid .ISO for the size requested.  Thankfully, I've found this is a padding issue only with building an image file and/or burning to disc directly from Encore.  The workaround is to build a BMDV folder instead, which has always been correct in my experience, and then use a program like IMGBURN (Windows; not sure of a mac equivalent) to burn to Blu-ray.
          • 2. Re: A couple of questions about burning Blu-rays in Encore
            This is exactly what I did and it fixed the problem.  I ended up building to a Blu-ray folder and burning the contents to a BD-R 25GB using imgBurn.  It worked perfectly.
            I hope Adobe fixes these issues in a future update, but at least it's good to know there's a workaround.
