1. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
UbuntuPenguin Jul 24, 2011 9:21 PM (in response to Echysttas)1 person found this helpfulAs for why the Dictionary eats more space when you store an XMLList vs a String, I would have to guess that an XMLList object has a larger memory footprint compared to the String. It's like asking why can I stuff more 5th graders into a phone booth as opposed to NFL linemen.
As for why there is a memory jump when you reprocess the XML I would have to see the code.
Protip: Use weak keys so your values can later be gc'ed when you are done with them.
2. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
Echysttas Jul 25, 2011 1:16 PM (in response to UbuntuPenguin)Hello and thank you for answering! ::- ).
I knew about the weak keys thing, but have not applied it. I didn't think it would be useful, and it might be, but I am still left with the question of why the memory increase ONLY WHEN PROCESSING one of the Dictionary's XMLs (going through its elements to initialize an object - and no, it's not because the object takes the space because the object is made up of primitive fields, and, more importantly, for demonstration's sake, I instantiated 100 more of the same object with NO MORE memory increase - so it just happens the first time).
3. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
Flex harUIJul 25, 2011 2:00 PM (in response to Echysttas)
1 person found this helpfulXML is parsed on-demand. When you assign a string and convert it to XML,
only the top-level node is actually fully created. I don't know the details
if sub-nodes have a partial representation or not. Then as you start
accessing sub-nodes, more XML objects are created. When you convert back
from XML to string and store string, the XML object can be garbage
collected, reducing total memory.
4. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
Echysttas Jul 25, 2011 10:53 PM (in response to Flex harUI)Hello ::- ). Thanks for clarifying!
I got 2 short confirmation sub-questions ::- ), just to wrap this up.
1. To make sure I really understood what happens: when I store XML Lists in the Dictionary, they are processed on first access (on demand practically) and will remain in memory for future access (that's why I can re-use them 100 times without further memory increase). But when I store Strings in the Dictionary and pull them out as XML in a function but not store them anywhere, they get GCed, obviously, and I get no memory penalty. Is this how it goes?
2. So what you're saying is that what I did is actually good practice, right?
5. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
Flex harUIJul 26, 2011 12:13 AM (in response to Echysttas)
I'm not sure I completely understood you, but I think the answer to #1 is
yes.
For #2, I don't see any upside to storing XML nodes in a Dictionary. In
fact, I believe that XML keys in Dictionary is not officially supported. If
you are looking to cache nodes, I would just cache the XMLList or an array
of nodes or in a Object keyed with strings if there is a convenient string
identifier.
If you are truly looking for speed, you would convert XML to objects if
possible.
6. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
Echysttas Jul 26, 2011 3:15 PM (in response to Flex harUI)Thank you very much for your reply & time Flex harUI ::- ).
BTW related to #1, if you care to say what you didn't understand of what I said, I will rephrase ::- ).
7. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
Flex harUIJul 26, 2011 3:28 PM (in response to Echysttas)
You were describing storing as a string and pulling out as an XML function
and not storing it. It would probably be better to see what code you
actually were talking about.
You could experience growth in the memory numbers depending on your code and
how the garbage collection runs. You could end up allocating extra memory
pages until the collector kicks in.
8. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
Echysttas Jul 27, 2011 6:23 AM (in response to Flex harUI)Well, ok, here's the code ::- ). I will paste you the 3 functions involved to:
1. Register XML data sets which are used to initialize Logicon Objects.
2. Demand for the initialization of an Object based on the earlier provided XML data.
3. Initialize the Object.
Note: _ObjectInitializationXMLMappery = new Dictionary(); //not weak.
Note: This code is used by a library which I built for in-game arithmetical calculations. The library is called Logicon and works with ILogiconObjects.
//Provides the Class with XML Data to use when initializing Logicon Objects.
//This Function may be called multiple times to add various XML data sets; however, conflicting Keys will be overwritten.
//PARAM data: XML data.
public function AddObjectInitializationXML (data: XML): void
var objects: XMLList = data.LO; //Retrieve & Process all individual Objects in the given Data.
//The Objects will be stored as String inside the Object Initialization XML Mapper because otherwise, tons of Memory will die.
for each (var obj: XML in objects)
{ //This object has a Unique Object Name.
if (obj.@UON != undefined)
//Create Dictionary Entry based on Unique Object Name. The Entry will contain all the Modifiers in this XML Node (M nodes).
_ObjectInitializationXMLMapper["N:" + String(obj.@UON)] = String(obj.M);
else //No UON.
_ObjectInitializationXMLMapper[int(obj.@ID)] = String(obj.M); //Create Dictionary Entry based on Object Type ID.
}//Initializes an object (from the earlier XML data).
//PARAM object: Logicon Object to initialize.
public function InitializeObject (object: ILogiconObject): void
var modifiers: String;
if (object.UniqueObjectName != null)
modifiers = _ObjectInitializationXMLMapper["N:" + object.UniqueObjectName];
else
modifiers = _ObjectInitializationXMLMapper[object.ObjectTypeID];
//No Modifiers found for this Object? Bye.
if (modifiers == null) return;
AddModifiersFromXMLToObject(modifiers, object); //Now add the Modifiers to the Object.
//Processes an XML List of Modifiers and adds them to a Logicon Object.
//PARAM modifiers: XML data to process.
//PARAM object: Logicon Object to which to add the Modifiers.
public function AddModifiersFromXMLToObject (modifiers: String, object: ILogiconObject): void
var noModifiers: Boolean = true; //TRUE: Throws an Error when no Modifiers are found in the XML.
//Process all Modifiers.
for each (var xm: XML in XMLList(modifiers))
{//And here I'm doing some stuff based on xm and its attributes.
//Stuff like object.SomeProperty = xm.@SomeAttribute, various checks, blah blah.
I really appreciate you taking an interest ::- D.
9. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
Flex harUIJul 27, 2011 1:39 PM (in response to Echysttas)
I think I see. You are using the dictionary to cache XML or string
representation of the XML of objects yet to be converted.
Seems like a lot of work to create the nodes in the XMLList, flatten to
strings and resurrect later. But maybe that's the right thing for how you
consume the objects. It appears there are lists of objects and usually,
those lists are managed and consumed in collections. Some folks simply
store the XMLList, front it with an Array and on getItemAt, convert the XML
node to the object and cache in the array.
10. Re: Allowing XML to be interpreted causes a 30 MB Memory Leak
Echysttas Jul 27, 2011 2:13 PM (in response to Flex harUI)Oh, what I forgot to mention (big mistake!) is that this is the NON-LEAKY version. So it's the fixed version which yields 16 MB RAM consumption.
I did that because the library supports adding multiple XMLs at run-time, at any given time, and, also, objects are initialized not very often. I would say 1 object / 3 seconds for the first minute of the game, then even less often, because I got an object pool and almost all intensively-created objects are pooled. (have experienced great problems in the past with Flash's GC because every time it gets invoked automatically, there is a slight stutter in the running application so I mitigated this by using object pools)
Your Array solution seems to behave in a way I find familiar. Probably that's exactly what the Dictionary does! I was storing XML directly in it, NOT STRING (like in the above example). And when I first accessed a Dictionary Key, its associated (XML) Value would be for-each-ed and, apparently, cached by Flash as a fully parsed XML. I think this is the way the Dictionary worked and resulted in the 47 MB of memory consumption: just like the cached Array you proposed.
The new version (pasted above) works with 16 MB because I keep Strings, process them and then immediately dump the processed XML.
I admit that this definitely wastes CPU clocks but it keeps the application light. Given my usage case: rare use, I find this acceptable.
