After my last edit - no syntax errors - of a given project, Flash Builder no longer builds my project.
Restarted Flash Builder. Created a new project and copied all sources. Nothing helps. It just doesn't create the binary.
I see two problem reports.
Most of the time this one:
An internal build error happened. See the error log for further details.
Then, sometimes, this one appears:
Classes aren't allowed to be defined inside other classes.
The project is syntactically free of errors.
As soon as I remove the main component from the App.mxml, the build finishes orderly and the app starts up. In this case - as expected - with a blank window.
Does a workaround solution exist? Does certain size restrictions make the build fail?
OS:
Mac OS X Lion.
Bug-Report:
Unbelieveable. After 2 day, I found the problem right now:
I wrote
private var baseNiceText = String = '';
instead of
private var baseNiceText : String = '';
After I changed the source and recompiled, the app builds.
Anyway, it's a problem inside of compiler.
As explained in the second post.
